Startup Issue with Minecraft - server won't start and says server jar is missing
Product AMP ‘Phobos’ v2.6.0.0 (Mainline)
its says the server jar is missing when I try and set up the Minecraft forge server
  • navigating to status
  • hovering mouse over start
  • pressing start
Log into your VM get into the amp user.
su -l amp
get into your docker instance:
docker exec -it dockername (EX: AMP_MinecraftServer) bash
cd /AMP/Minecraft/
Check if you see minecraft_server.jar in that directory.
You don’t have to go into the docker container, all the files are accessible via the file manager.
That’s also just the wrong Jar for a Forge server.
The Jar should be set to Autoselect, and the version of Forge you’re running, then you just hit Download/Update
