Startup Issue with Minecraft - Server wont start after making instance
Operating System Linux - Debian GNU/Linux 13 on aarch64
Product AMP ‘Deimos’ v2.7.2.0 (Mainline)
I create my minecraft instance and configure it to be a paper 26.1.2 server and it says that the instance wont start after 5 seconds of running. The java version is the correct version for 26.1.2 (java 25)
It is also worth mentioning that it produces no log and the error from the console is the error saying that the incorrect java version is installed (the one that says class 69 or something) However i am 100% sure that java 25 is selected
  • Create Instance
  • Configure settings / select server jar
  • Start the instance
same issue.
I don’t know why server keeps using java 21 (as default) while java 25 is selected
