| Operating System | Windows - Windows 10 Home on x86_64 |
| Product | AMP ‘Callisto’ v2.5.0.8 (Mainline) |
| Virtualization | None |
| Application | Minecraft |
| Module | MinecraftModule |
| Running in Container | No |
| Current State | Failed |
the server starts and shuts off and I have no clue what could be causing this since its a fresh install.
"Console
03:01:56
2024-05-15 03:01:56,801 main WARN Advanced terminal features are not available in this environment
main/INFO
03:01:56
ModLauncher running: args [–launchTarget, forgeserver, --fml.forgeVersion, 47.2.32, --fml.mcVersion, 1.20.1, --fml.forgeGroup, net.minecraftforge, --fml.mcpVersion, 20230612.114412]
ModLauncher 10.0.9+10.0.9+main.dcd20f30 starting: java version 22.0.1 by Oracle Corporation; OS Windows 10 arch amd64 version 10.0
03:02:01
ImmediateWindowProvider not loading because launch target is forgeserver
Mixin Transmogrifier is definitely up to no good…
crimes against java were committed
Redirector CoreMod initialized successfully!
Original mixin transformation service successfully crobbed by mixin-transmogrifier!
SpongePowered MIXIN Subsystem Version=0.8.5 Source=union:/D:/AMPDatastore/Instances/Minecraft01/Minecraft/mods/Connector-1.0.0-beta.36+1.20.1.jar%23324%23328!/ Service=ModLauncher Env=SERVER
main/WARN
03:02:01
Mod file D:\AMPDatastore\Instances\Minecraft01\Minecraft\libraries\net\minecraftforge\fmlcore\1.20.1-47.2.32\fmlcore-1.20.1-47.2.32.jar is missing mods.toml file
Mod file D:\AMPDatastore\Instances\Minecraft01\Minecraft\libraries\net\minecraftforge\javafmllanguage\1.20.1-47.2.32\javafmllanguage-1.20.1-47.2.32.jar is missing mods.toml file
Mod file D:\AMPDatastore\Instances\Minecraft01\Minecraft\libraries\net\minecraftforge\lowcodelanguage\1.20.1-47.2.32\lowcodelanguage-1.20.1-47.2.32.jar is missing mods.toml file
Mod file D:\AMPDatastore\Instances\Minecraft01\Minecraft\libraries\net\minecraftforge\mclanguage\1.20.1-47.2.32\mclanguage-1.20.1-47.2.32.jar is missing mods.toml file
03:02:02
Attempted to select two dependency jars from JarJar which have the same identification: Mod File: and Mod File: . Using Mod File:
Attempted to select a dependency jar for JarJar which was passed in as source: terrablender. Using Mod File: D:\AMPDatastore\Instances\Minecraft01\Minecraft\mods\TerraBlender-forge-1.20.1-3.0.1.4.jar
Attempted to select a dependency jar for JarJar which was passed in as source: aeroblender. Using Mod File: D:\AMPDatastore\Instances\Minecraft01\Minecraft\mods\aeroblender-1.20.1-1.0.1-neoforge.jar
Attempted to select a dependency jar for JarJar which was passed in as source: curios. Using Mod File: D:\AMPDatastore\Instances\Minecraft01\Minecraft\mods\curios-forge-5.7.0+1.20.1.jar
main/INFO
03:02:02
Found 79 dependencies adding them to mods collection
Dependency resolution found 6 candidates to load
03:02:04
Successfully made module authlib transformable
Console
03:02:05
stoneworks 8.0.0
stonycliffs 1.0.0
storagenetwork 1.10.0
structory 1.3.4
structorytowers 1.0.6
structure_gel 2.16.0
structureessentials 1.20.1-3.2
supplementaries 1.20-2.7.35
suppsquared 1.20-1.1.12
t_and_t 0.0NONE
terrablender 3.0.1.4
toofast 0.4.3.5
tradingpost 8.0.2
transparent 8.0.1+1.20.1
twigs 1.20.1-3.1.1
twilightdelight 2.0.4
twilightforest 4.3.2145
umbral_skies 1.3
veinmining 1.3.0+1.20.1
villagernames 7.3
villagersplus 3.1
villagesandpillages 1.0.0
visuality 2.0.2
visualworkbench 8.0.0
voidtotem 3.0.1
watut 1.20.1-1.0.13
waystones 14.1.3
whatareyouvotingfor 1.2.3
wunderlib 1.1.5
xaerominimap 23.9.7
xaeroworldmap 1.37.8
xenon 0.3.1-git.7a8395b.dirty+mc1.20.1
xpbook 2.2
yeetusexperimentus 2.3.1-build.6+mc1.20.1
ysns 1.0.2
yungsapi 1.20-Forge-4.0.3
yungsbridges 1.20-Forge-4.0.3
zeta 1.0-13
main/WARN
03:02:05
Reference map ‘cristellib-forge-refmap.json’ for cristellib.mixins.json could not be read. If this is a development environment you can ignore this message
Reference map ‘cuisinedelight.refmap.json’ for cuisinedelight.mixins.json could not be read. If this is a development environment you can ignore this message
Reference map ‘suppsquared-common-refmap.json’ for suppsquared-common.mixins.json could not be read. If this is a development environment you can ignore this message
Reference map ‘suppsquared-forge-refmap.json’ for suppsquared.mixins.json could not be read. If this is a development environment you can ignore this message
Reference map ‘coroutil.refmap.json’ for coroutil.mixins.json could not be read. If this is a development environment you can ignore this message
Reference map ‘PacketFixer-forge-forge-refmap.json’ for packetfixer-forge.mixins.json could not be read. If this is a development environment you can ignore this message
Console
03:02:05
[Serene Seasons Transformer]: Transforming m_47480_ (Lnet/minecraft/world/level/LevelReader;Lnet/minecraft/core/BlockPos;Z)Z in net/minecraft/world/level/biome/Biome
[Serene Seasons Transformer]: Patched 1 calls
[Serene Seasons Transformer]: Transforming m_47519_ (Lnet/minecraft/world/level/LevelReader;Lnet/minecraft/core/BlockPos;)Z in net/minecraft/world/level/biome/Biome
[Serene Seasons Transformer]: Successfully patched shouldSnow
main/ERROR
03:02:06
Attempted to load class net/minecraft/client/MouseHandler for invalid dist DEDICATED_SERVER
main/WARN
03:02:06
Error loading class: net/minecraft/client/MouseHandler (java.lang.RuntimeException: Attempted to load class net/minecraft/client/MouseHandler for invalid dist DEDICATED_SERVER)
@Mixin target net.minecraft.client.MouseHandler was not found fabric-screen-api-v1.mixins.json:MouseMixin from mod fabric_screen_api_v1
main/ERROR
03:02:06
Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER
main/WARN
03:02:06
Error loading class: net/minecraft/client/gui/screens/Screen (java.lang.RuntimeException: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER)
@Mixin target net.minecraft.client.gui.screens.Screen was not found fabric-screen-api-v1.mixins.json:ScreenAccessor from mod fabric_screen_api_v1
Force-disabling mixin ‘alloc.blockstate.StateMixin’ as option ‘mixin.alloc.blockstate’ (added by mods [ferritecore]) disables it and children
Force-disabling mixin ‘entity.collisions.fluid.EntityMixin’ as option ‘mixin.entity.collisions’ (added by user configuration) disables it and children
Force-disabling mixin ‘entity.collisions.intersection.WorldMixin’ as option ‘mixin.entity.collisions’ (added by user configuration) disables it and children
Force-disabling mixin ‘entity.collisions.movement.EntityMixin’ as option ‘mixin.entity.collisions’ (added by user configuration) disables it and children
Force-disabling mixin ‘entity.collisions.unpushable_cramming.AbstractMinecartEntityMixin’ as option ‘mixin.entity.collisions’ (added by user configuration) disables it and children
Force-disabling mixin ‘entity.collisions.unpushable_cramming.BoatEntityMixin’ as option ‘mixin.entity.collisions’ (added by user configuration) disables it and children
Force-disabling mixin ‘entity.collisions.unpushable_cramming.EntityMixin’ as option ‘mixin.entity.collisions’ (added by user configuration) disables it and children
Force-disabling mixin ‘entity.collisions.unpushable_cramming.EntityPredicatesMixin’ as option ‘mixin.entity.collisions’ (added by user configuration) disables it and children
Force-disabling mixin ‘entity.collisions.unpushable_cramming.EntityTrackingSectionMixin’ as option ‘mixin.entity.collisions’ (added by user configuration) disables it and children
Force-disabling mixin ‘entity.collisions.unpushable_cramming.LivingEntityMixin’ as option ‘mixin.entity.collisions’ (added by user configuration) disables it and children
Force-disabling mixin ‘world.block_entity_ticking.sleeping.ServerWorldMixin’ as option ‘mixin.world.block_entity_ticking.sleeping’ (added by user configuration) disables it and children
Force-disabling mixin ‘world.block_entity_ticking.sleeping.WorldChunkMixin’ as option ‘mixin.world.block_entity_ticking.sleeping’ (added by user configuration) disables it and children
Force-disabling mixin ‘world.block_entity_ticking.sleeping.WorldMixin’ as option ‘mixin.world.block_entity_ticking.sleeping’ (added by user configuration) disables it and children
Force-disabling mixin ‘world.block_entity_ticking.sleeping.WrappedBlockEntityTickInvokerAccessor’ as option ‘mixin.world.block_entity_ticking.sleeping’ (added by user configuration) disables it and children
Force-disabling mixin ‘world.block_entity_ticking.sleeping.brewing_stand.BrewingStandBlockEntityMixin’ as option ‘mixin.world.block_entity_ticking.sleeping’ (added by user configuration) disables it and children
Force-disabling mixin ‘world.block_entity_ticking.sleeping.campfire.CampfireBlockEntityMixin’ as option ‘mixin.world.block_entity_ticking.sleeping’ (added by user configuration) disables it and children
Force-disabling mixin ‘world.block_entity_ticking.sleeping.campfire.lit.CampfireBlockEntityMixin’ as option ‘mixin.world.block_entity_ticking.sleeping’ (added by user configuration) disables it and children
Force-disabling mixin ‘world.block_entity_ticking.sleeping.campfire.unlit.CampfireBlockEntityMixin’ as option ‘mixin.world.block_entity_ticking.sleeping’ (added by user configuration) disables it and children
Force-disabling mixin ‘world.block_entity_ticking.sleeping.furnace.AbstractFurnaceBlockEntityMixin’ as option ‘mixin.world.block_entity_ticking.sleeping’ (added by user configuration) disables it and children
Force-disabling mixin ‘world.block_entity_ticking.sleeping.hopper.HopperBlockEntityMixin’ as option ‘mixin.world.block_entity_ticking.sleeping’ (added by user configuration) disables it and children
Force-disabling mixin ‘world.block_entity_ticking.sleeping.shulker_box.ShulkerBoxBlockEntityMixin’ as option ‘mixin.world.block_entity_ticking.sleeping’ (added by user configuration) disables it and children
main/INFO
03:02:06
Loaded config for: recipeessentials.json
Loaded config for: structureessentials.json
main/WARN
03:02:06
Error loading class: net/minecraft/client/renderer/entity/PhantomRenderer (java.lang.ClassNotFoundException: net.minecraft.client.renderer.entity.PhantomRenderer)
@Mixin target net.minecraft.client.renderer.entity.PhantomRenderer was not found mixins.deeperdarker.json:PhantomRendererMixin from mod deeperdarker
main/ERROR
03:02:06
Attempted to load class net/minecraft/client/gui/screens/multiplayer/ServerSelectionList for invalid dist DEDICATED_SERVER
main/WARN
03:02:06
Error loading class: net/minecraft/client/gui/screens/multiplayer/ServerSelectionList (java.lang.RuntimeException: Attempted to load class net/minecraft/client/gui/screens/multiplayer/ServerSelectionList for invalid dist DEDICATED_SERVER)
@Mixin target net.minecraft.client.gui.screens.multiplayer.ServerSelectionList was not found serverbrowser.mixins.json:ServerSelectionMixin from mod serverbrowser
Error loading class: noobanidus/mods/lootr/config/ConfigManager (java.lang.ClassNotFoundException: noobanidus.mods.lootr.config.ConfigManager)
For can’t fit X into 3 error fix. Delete Krypton or Pluto.
Error loading class: com/mojang/blaze3d/audio/Channel (java.lang.ClassNotFoundException: com.mojang.blaze3d.audio.Channel)
@Mixin target com.mojang.blaze3d.audio.Channel was not found assets/sound_physics_remastered/sound_physics_remastered.mixins.json:ChannelAccessor from mod (unknown)
main/INFO
03:02:06
[MemoryLeakFix]: Will be applying 1 memory leak fixes!
[MemoryLeakFix]: Currently enabled memory leak fixes: [biomeTemperatureLeak]
Initializing MixinExtras via com.llamalad7.mixinextras.service.MixinExtrasServiceImpl(version=0.3.2).
main/WARN
03:02:06
Found problematic active MixinExtras instance at ca.fxco.memoryleakfix.mixinextras (version 0.2.0-beta.8)
Versions from 0.2.0-beta.1 to 0.2.0-beta.9 have limited support and it is strongly recommended to update.
main/INFO
03:02:07
Mixing server.MixinDedicatedServer from mixins/common/nochatreports.mixins.json into net.minecraft.server.dedicated.DedicatedServer
main/WARN
03:02:07
Failed to add counter for PDH counter: \Paging File(_Total)% Usage
Disabling further attempts to query Paging File.
03:02:08
COM exception: Invalid Query: SELECT PERCENTUSAGE FROM Win32_PerfRawData_PerfOS_PagingFile
main/INFO
03:02:08
ModernFix reached bootstrap stage (13.73 s after launch)
Mixing common.MixinFriendlyByteBuf from mixins/common/nochatreports.mixins.json into net.minecraft.network.FriendlyByteBuf
Renaming synthetic method lambda$onWriteJsonWithCodec$1(Ljava/lang/Object;Ljava/lang/String;)Lio/netty/handler/codec/EncoderException; to mde016c5$nochatreports$lambda$onWriteJsonWithCodec$1$0 in mixins/common/nochatreports.mixins.json:common.MixinFriendlyByteBuf from mod nochatreports
Renaming synthetic method lambda$onReadJsonWithCodec$0(Ljava/lang/String;)Lio/netty/handler/codec/DecoderException; to mde016c5$nochatreports$lambda$onReadJsonWithCodec$0$1 in mixins/common/nochatreports.mixins.json:common.MixinFriendlyByteBuf from mod nochatreports
Injecting BlockStateBase cache population hook into getNeighborPathNodeType from me.jellysquid.mods.lithium.mixin.ai.pathing.AbstractBlockStateMixin
Injecting BlockStateBase cache population hook into getPathNodeType from me.jellysquid.mods.lithium.mixin.ai.pathing.AbstractBlockStateMixin
Injecting BlockStateBase cache population hook into getAllFlags from me.jellysquid.mods.lithium.mixin.util.block_tracking.AbstractBlockStateMixin
03:02:09
Vanilla bootstrap took 1087 milliseconds
main/WARN
03:02:09
@ModifyConstant conflict. Skipping connectivity.mixins.json:ClientBoundCustomPayloadPacketLMixin from mod connectivity->@ModifyConstant::modifyLimit(I)I with priority 1, already redirected by packetfixer-common.mixins.json:ClientboundCustomPayloadPacketMixin from mod packetfixer->@ModifyConstant::newSize(I)I with priority 9999
Console
03:02:10
… 12 more
Caused by: net.minecraft.ReportedException: Radium Class Analysis
at TRANSFORMER/radium@0.12.2+git.5f80f74/me.jellysquid.mods.lithium.common.reflection.ReflectionUtil.hasMethodOverride(ReflectionUtil.java:36)
at TRANSFORMER/radium@0.12.2+git.5f80f74/me.jellysquid.mods.lithium.common.ai.pathing.BlockClassChecker.lambda$hasNonstandardImplementation$0(BlockClassChecker.java:30)
at java.base/java.util.concurrent.ConcurrentHashMap.computeIfAbsent(ConcurrentHashMap.java:1710)
at TRANSFORMER/radium@0.12.2+git.5f80f74/me.jellysquid.mods.lithium.common.ai.pathing.BlockClassChecker.shouldUseDynamicTypeCheck(BlockClassChecker.java:22)
at TRANSFORMER/minecraft@1.20.1/net.minecraft.world.level.block.Block.handler$zlb000$radium$postConstruct(Block.java:1639)
at TRANSFORMER/minecraft@1.20.1/net.minecraft.world.level.block.Block.(Block.java:181)
at TRANSFORMER/minecraft@1.20.1/net.minecraft.world.level.block.CraftingTableBlock.(CraftingTableBlock.java:21)
at TRANSFORMER/minecraft@1.20.1/net.minecraft.world.level.block.Blocks.(Blocks.java:241)
… 16 more
Caused by: org.spongepowered.asm.mixin.transformer.throwables.MixinTransformerError: An unexpected critical error was encountered
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.mixin.transformer.MixinProcessor.applyMixins(MixinProcessor.java:392)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.mixin.transformer.MixinTransformer.transformClass(MixinTransformer.java:250)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.service.modlauncher.MixinTransformationHandler.processClass(MixinTransformationHandler.java:131)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.launch.MixinLaunchPluginLegacy.processClass(MixinLaunchPluginLegacy.java:131)
at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.serviceapi.ILaunchPluginService.processClassWithFlags(ILaunchPluginService.java:156)
at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.LaunchPluginHandler.offerClassNodeToPlugins(LaunchPluginHandler.java:88)
at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.ClassTransformer.transform(ClassTransformer.java:120)
at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.TransformingClassLoader.maybeTransformClassBytes(TransformingClassLoader.java:50)
at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.readerToClass(ModuleClassLoader.java:113)
at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.lambda$findClass$15(ModuleClassLoader.java:219)
at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.loadFromModule(ModuleClassLoader.java:229)
at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.findClass(ModuleClassLoader.java:219)
at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.loadClass(ModuleClassLoader.java:135)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:525)
at java.base/java.lang.Class.getDeclaredMethods0(Native Method)
at java.base/java.lang.Class.privateGetDeclaredMethods(Class.java:3601)
at java.base/java.lang.Class.getDeclaredMethod(Class.java:2856)
at TRANSFORMER/radium@0.12.2+git.5f80f74/me.jellysquid.mods.lithium.common.reflection.ReflectionUtil.hasMethodOverride(ReflectionUtil.java:13)
… 23 more
Caused by: org.spongepowered.asm.mixin.injection.throwables.InjectionError: Critical injection failure: Callback method catchTickingItemStack(Lnet/minecraft/world/item/ItemStack;Lnet/minecraft/world/level/Level;Lnet/minecraft/world/entity/Entity;IZLcom/llamalad7/mixinextras/injector/wrapoperation/Operation;)V in neruina-common.mixins.json:PlayerInventoryMixin from mod neruina failed injection check, (0/1) succeeded. Scanned 1 target(s). Using refmap neruina-common-refmap.json
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.mixin.injection.struct.InjectionInfo.postInject(InjectionInfo.java:468)
at TRANSFORMER/MixinExtras@0.3.2/com.llamalad7.mixinextras.injector.wrapoperation.WrapOperationInjectionInfo.latePostInject(WrapOperationInjectionInfo.java:76)
at TRANSFORMER/MixinExtras@0.3.2/com.llamalad7.mixinextras.injector.wrapoperation.WrapOperationApplicatorExtension.postApply(WrapOperationApplicatorExtension.java:39)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.mixin.transformer.ext.Extensions.postApply(Extensions.java:167)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.mixin.transformer.TargetClassContext.postApply(TargetClassContext.java:432)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.mixin.transformer.TargetClassContext.applyMixins(TargetClassContext.java:405)
at MC-BOOTSTRAP/org.spongepowered.mixin/org.spongepowered.asm.mixin.transformer.MixinProcessor.applyMixins(MixinProcessor.java:363)
… 40 more"
- make the instance
- change it to forge
- install the server pack from curse forge
- add the serverpack files via SCP
- Start the server and it crashes immediately
