| Product | AMP ‘Phobos’ v2.6.0.12 (Mainline) |
| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Failed |
We installed the correct version of forge and then installed the mods from .jar files, The mods work on my curseforge instance so im not sure why they might not be working here. I can send you the code to make a duplicate of my curseforge instance if you would like?
- Install forge for 1.20.1, make sure its version 47.3.0
- Then create a mod folder, install the .jar files for the mods, code for forge profile is egcS3F_0
- update the installation and run the server
