Startup Issue with Minecraft - server minecraft mods refuses to start
Even after doing the configuration, updating the server, checking the versions of Minecraft and Forge, testing with the RAM and initial memory configuration and after testing by changing them, the server refuses to start each time. I want to create a Minecraft server modded in 1.20.1 with Forge containing around fifty mods
  • I went to the server configuration page, I installed a server running with forge
  • once forge installed I selected the version of minecraft associated with forge with which I wanted to play
  • once this was done I updated the server and added the mods I wanted to play with. These are around fifty mods
Best bet is to read the latest.log to see what could be going wrong
I cannot read or download the logs
If you’re having trouble downloading it from the browser, you can use SFTP (connection details in the upper right of the file manager)
