Field | Value |
Product | AMP ‘Phobos’ v2.6.0.6 (Mainline) |
Virtualization | Docker |
Application | Minecraft |
Module | MinecraftModule |
Running in Container | Yes |
Current State | Starting |
I changed some attributes in the config file of the puffish skill tree mod in order to balance it, however, while the server was restarting in order to apply the changes, I remembered I need to change one attribete more, so I did it and saved the changes of the file while the server was still restarting, I waited a bit to see if I would need to restart again when it loads to apply the new change, but it never loaded, so I aborted it and treied to start again, now the server does not start again
- Change config file of a mod, no mistakes made while doing it
- Click to restart the server
- While starting, remember something that I forgot to do in the config
- Do it and save while it still is restarting
- Does not load anymore, try aborting and starting again
- Server does not start anymore
