| Product | AMP ‘Callisto’ v2.5.1.0 (Mainline) |
| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Stopped |
Whenever I try to start my Minecraft server with all the logs it keeps getting stuck on the line of code below. I am trying to use the BetterMC modpack. Any help would be appreciated!
FML: 47.3
Forge: net.minecraftforge:47.3.1[00:30:46] [main/ERROR] [minecraft/Main]: Failed to start the minecraft server
net.minecraftforge.fml.LoadingFailedException: Loading errors encountered: [
Oculus (oculus) has failed to load correctly
?7java.lang.RuntimeException: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER,
YUNG’s Menu Tweaks (yungsmenutweaks) has failed to load correctly
?7java.util.ServiceConfigurationError: com.yungnickyoung.minecraft.yungsmenutweaks.services.IPlatformHelper: com.yungnickyoung.minecraft.yungsmenutweaks.services.ForgePlatformHelper Unable to get public no-arg constructor,
RyoamicLights (ryoamiclights) has failed to load correctly
Euphoria Patcher (euphoria_patcher) has failed to load correctly
?7java.lang.NoClassDefFoundError: org/apache/commons/compress/compressors/CompressorException,
Entity Model Features (entity_model_features) has failed to load correctly
?7java.lang.UnsupportedOperationException: Attempting to load a clientside only mod [EMF] on the server, refusing,
Entity Texture Features (entity_texture_features) has failed to load correctly
?7java.lang.UnsupportedOperationException: Attempting to load a clientside only mod on the server, refusing,
CIT Resewn (citresewn) has failed to load correctly
?7java.lang.NoClassDefFoundError: net/minecraft/client/renderer/texture/atlas/SpriteSource
at net.minecraftforge.fml.ModLoader.waitForTransition(ModLoader.java:246) ~[fmlcore-1.20.1-47.3.1.jar%23654!/:?] {}
at net.minecraftforge.fml.ModLoader.lambda$dispatchAndHandleError$20(ModLoader.java:210) ~[fmlcore-1.20.1-47.3.1.jar%23654!/:?] {}
at java.util.Optional.ifPresent(Optional.java:178) ~[?:?] {re:mixin}
at net.minecraftforge.fml.ModLoader.dispatchAndHandleError(ModLoader.java:210) ~[fmlcore-1.20.1-47.3.1.jar%23654!/:?] {}
at net.minecraftforge.fml.ModLoader.lambda$gatherAndInitializeMods$13(ModLoader.java:183) ~[fmlcore-1.20.1-47.3.1.jar%23654!/:?] {}
at java.lang.Iterable.forEach(Iterable.java:75) ~[?:?] {re:mixin}
at net.minecraftforge.fml.ModLoader.gatherAndInitializeMods(ModLoader.java:183) ~[fmlcore-1.20.1-47.3.1.jar%23654!/:?] {}
at net.minecraftforge.server.loading.ServerModLoader.load(ServerModLoader.java:30) ~[forge-1.20.1-47.3.1-universal.jar%23658!/:?] {re:classloading}
at net.minecraft.server.Main.main(Main.java:125) ~[server-1.20.1-20230612.114412-srg.jar%23653!/:?] {re:mixin,pl:connector_pre_launch:A,re:classloading,re:mixin,pl:connector_pre_launch:A,pl:mixin:A,pl:connector_pre_launch:A}
at jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103) ~[?:?] {}
at java.lang.reflect.Method.invoke(Method.java:580) ~[?:?] {}
at net.minecraftforge.fml.loading.targets.CommonLaunchHandler.runTarget(CommonLaunchHandler.java:111) ~[fmlloader-1.20.1-47.3.1.jar%2369!/:?] {}
at net.minecraftforge.fml.loading.targets.CommonLaunchHandler.serverService(CommonLaunchHandler.java:103) ~[fmlloader-1.20.1-47.3.1.jar%2369!/:?] {}
at net.minecraftforge.fml.loading.targets.CommonServerLaunchHandler.lambda$makeService$0(CommonServerLaunchHandler.java:27) ~[fmlloader-1.20.1-47.3.1.jar%2369!/:?] {}
at cpw.mods.modlauncher.LaunchServiceHandlerDecorator.launch(LaunchServiceHandlerDecorator.java:30) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.LaunchServiceHandler.launch(LaunchServiceHandler.java:53) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.LaunchServiceHandler.launch(LaunchServiceHandler.java:71) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.Launcher.run(Launcher.java:108) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.Launcher.main(Launcher.java:78) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.BootstrapLaunchConsumer.accept(BootstrapLaunchConsumer.java:26) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.BootstrapLaunchConsumer.accept(BootstrapLaunchConsumer.java:23) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.bootstraplauncher.BootstrapLauncher.main(BootstrapLauncher.java:141) ~[bootstraplauncher-1.1.2.jar:?] {}
- Add mods to file manager
- Start Server through the game panel
- Console fails to connect
