Startup Issue with Minecraft - server fails to launch, failure with mods
Crash Report UUID: 912a7a34-e57f-4d41-baa0-b3199a29bb5c[00:14:09] [main/FATAL] [minecraft/Main]: Failed to start the minecraft server
net.minecraftforge.fml.LoadingFailedException: Loading errors encountered: [
Pixelmon TCG (tcg) has failed to load correctly
?7org.spongepowered.asm.mixin.transformer.throwables.MixinTransformerError: An unexpected critical error was encountered,
Pixelmon Mod (pixelmon) has failed to load correctly
-and-
Caused by: org.spongepowered.asm.mixin.throwables.ClassMetadataNotFoundException: net.minecraft.client.Minecraft
  • follow the mod installing guide
  • add pixelmon mod to mods file (both the server and standard mod fail)
  • launch the server
  • check the server logs
  1. Go into the settings, select the version of Forge that you want, and press Donwload/Update
  2. See if it starts
  3. Try running the server without pixelmon and make sure forge starts correctly.
    i. If so, delete the world folder before adding pixelmon again
  4. Make sure you’re using the right Java version for the version of Forge you’re running
Also, take a read through this FAQ here if you run into further issues:
it was ran with the settings we want, we already fixed the first error: The first error we ran into was a known error with java. downgrading to 11 fixed this. the next issue were 2 conflicting mods which caused the load of the pixelmon mods to fail. Cause 1: Essential, Cause 2: Cloth API and Chest Cavity Forge. Cloth API works for Forge Neoforge and Fabric, but caused errors with Chest Cavity Forge. changing from Chest Cavity Forge to Chest cavity fabric fixed this issue as well.
Edit: Chest cavity fabric doesn’t work when ran and can corrupt the world, Only fix is to remove chest cavity.
