Startup Issue with Minecraft - Server fails after a few seconds
Operating System Windows - Windows 11 Home on x86_64
I tried starting the server multiple times and it gives me this error message: Error: Could not find or load main class @libraries.net.neoforged.neoforge.21.1.131.win_args.txt
  • I made the server instance
  • I moved all the files over into the file manager that I believe I need
  • I hit the start server button and it failed after a few seconds and gave the below error msg
You need to select Java 21 under Java and Memory
