Startup Issue with Minecraft - Server Failed to Start
Operating System Linux - Ubuntu 22.04.4 on x86_64
Product AMP ‘Callisto’ v2.5.0.8 (Mainline)
Virtualization OpenVZ
Application is not starting.
This is in the logs:
java.lang.UnsupportedClassVersionrecognizes class file versions up to 63.0Error: net/minecraft/bundler/Main has been compiled by a more recent version of the Java Runtime (class file version 65.0), this version of the Java Runtime only
  • Stop the instance.
  • start the instance
  • Application is in a stopped state so I reviewed the logs. They show the below error about version mismatch.
What java version are you using? You need to use Java 21 for this
