Startup Issue with Minecraft - Server does not start
Virtualization QEMU_KVM
i changed my View Distance a few times to play around and check it out ingame but after like 4 restarts my gameserver will not start anymore it tells me to check my server settings
  • changes View Distance
  • deleting server prop files
  • set all settings back to normal
What does the console say?
Console
18:04:50
Picked up _JAVA_OPTIONS: -Djdk.net.URLClassPath.disableClassPathURLCheck=true
Error: A JNI error has occurred, please check your installation and try again
Exception in thread “main” java.lang.UnsupportedClassVersionError: org/bukkit/craftbukkit/bootstrap/Main has been compiled by a more recent version of the Java Runtime (class file version 61.0), this version of the Java Runtime only recognizes class file versions up to 52.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:756)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:468)
at java.net.URLClassLoader.access$100(URLClassLoader.java:74)
at java.net.URLClassLoader$1.run(URLClassLoader.java:369)
at java.net.URLClassLoader$1.run(URLClassLoader.java:363)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:362)
at java.lang.ClassLoader.loadClass(ClassLoader.java:418)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:352)
at java.lang.ClassLoader.loadClass(ClassLoader.java:351)
at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:601)
i dont know if u want to see this
Wrong java version selected - select a newer version of Java in AMPs settings.
im looking around but coudnt finde the settings to do this
Type “Java Version” into AMPs search box in the top right while managing the instance.
okey thanks im just stupid :smiley: it worked
