Startup Issue with Minecraft - Server crashing because of --log-strip-color
Product AMP ‘Deimos’ v2.7.2.4 (Mainline)
Please remove --log-strip-color from my Minecraft server startup arguments.
  • Change Server to use PaperMc,
  • Use newest minecraft version
  • Start the server
  • Look at console
Change the Paper Version to something else, then back to the version you want
I have the same Issues, changing version to something else, then back to the version i want dont do anything. Its still dont want to start.
Im using a fork of Folia (CanvasMC), Version 1.21.11
AMP Version : v2.7.2.4
SEVERE: log-strip-color is not a recognized option
You need to update AMP to the latest version.
Hooray! AMP is up-to-date.
Currently running version 2.7.2.6 - 20260514.2
And still the same error : SEVERE: log-strip-color is not a recognized option
Change the Folia version to something else them back to the one you want.
Still not working same error,
Changed the version and return back and still not working….
Ahh just realized you’re using CanvasMC. What did you select for server type?
Server Type : Folia
Folia Version : 1.21.11
Server JAR : canvas-build.703.jar
CanvasMC is a fork of Folia
Try selecting 26 for the version. It looks like Canvas isn’t a directly compatible version.
