Field | Value |
Product | AMP ‘Callisto’ v2.5.0.10 (Mainline) |
Virtualization | Docker |
Application | Minecraft |
Module | MinecraftModule |
Running in Container | Yes |
Current State | Failed |
So basically, I tried to re-run my server that we just started TODAY, and basically after turning i off for a fe hours it suddenly appeared that our data failed to load into the server and after checking the logs it didn’t even said anything other than “data couldn’t load into server”
- Start up Instance
- Check Change Log if anything crashes/doesn’t load
- Error appears
- Tries to see from where but only says that data doesn’t work
