Startup Issue with Minecraft - Server can't start
Product AMP ‘Phobos’ v2.6.0.10 (Mainline)
It just can’t start. I got the version of forge for 1.20.1 installed, used SFTP to copy over the mod folder and the config folder for the server version of the modpack Fantasy Skies on CurseForge, stopped the server, updated it, and tried to restart it, but it keeps failing to start.
  • Press Start button
  • CPU usage maxes out
  • Error starting up
The error should tell you what’s wrong
The error message says:
Unable to start server.
The Minecraft server repeatedly failed to start, this is not a fault with AMP - you should check your Minecraft servers log files to find out why it is unable to start.
I’m here asking for help because I didn’t know how or what to change.
You should check your Minecraft servers log files to find out why it is unable to start.
Because we can’t read minds (ie, can’t help you if you don’t share the error)
