Startup Issue with Minecraft - RLCraft Dregora Minecraft Modpack server wont start
Operating System Windows - Windows 11 Home on x86_64
Product AMP ‘Phobos’ v2.6.3.0 (Mainline)
I’ve followed every tutorial I can find and I’ve gotten everything I needed in the right place. The server is not started for whatever reason it seems to get stuck in the same spot when I watch the console as it boots up. I have the correct java version and every thread I’ve seen about people failing to start this exact modpack up the answer response is always just “Make sure you’re on the right java version”. Not sure what else I can do or if this modpack just might not work for AMP
  • Uploaded server files and mods
  • Selected correct java version (JDK 8 for 1.12.2)
  • Configured Server Settings for specific modpack’s needs
Where it gets stuck in console:
This was not an issue with amp, but with a weird interaction the modpack creator setup their server files. I just went through this myself and upon searching their discord server the only fix I saw was to delete the Mod-director folder entirely
