Startup Issue with Minecraft - problem with starting a server . erros issue
Unrecognized option: --gameDir=.,
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
  • instaled server
  • changed version of mc/forge/java on correctly
  • added mods and instaled them on the server
  • first error with arguments
  • added arguments to startup
  • next errror with virtual machine
Remove any Xmx, Xms, or jar arguments.
Or remove all the arguments and slowly add them back to see which ones error
main/INFO
18:54:38
ModLauncher running: args [–gameDir, ., --launchTarget, fmlserver, --fml.forgeVersion, 36.2.39, --fml.mcpVersion, 20210115.111550, --fml.mcVersion, 1.16.5, --fml.forgeGroup, net.minecraftforge, nogui]
ModLauncher 8.1.3+8.1.3+main-8.1.x.c94d18ec starting: java version 1.8.0_402 by Temurin
Added Lets Encrypt root certificates as additional trust
SpongePowered MIXIN Subsystem Version=0.8.4 Source=file:/AMP/Minecraft/libraries/org/spongepowered/mixin/0.8.4/mixin-0.8.4.jar Service=ModLauncher Env=SERVER
[java.lang.ThreadGroup:uncaughtException:1052]: com.electronwill.nightconfig.core.io.WritingException: An I/O error occured
[java.lang.ThreadGroup:uncaughtException:1052]: at com.electronwill.nightconfig.core.io.ConfigWriter.write(ConfigWriter.java:90)
[java.lang.ThreadGroup:uncaughtException:1052]: at com.electronwill.nightconfig.core.file.WriteSyncFileConfig.save(WriteSyncFileConfig.java:61)
18:54:39
[java.lang.ThreadGroup:uncaughtException:1052]: at com.electronwill.nightconfig.core.file.AutoreloadFileConfig.save(AutoreloadFileConfig.java:36)
[java.lang.ThreadGroup:uncaughtException:1052]: at com.electronwill.nightconfig.core.file.AutosaveCommentedFileConfig.save(AutosaveCommentedFileConfig.java:80)
[java.lang.ThreadGroup:uncaughtException:1052]: at net.minecraftforge.fml.loading.FMLConfig.loadFrom(FMLConfig.java:57)
[java.lang.ThreadGroup:uncaughtException:1052]: at net.minecraftforge.fml.loading.FMLConfig.load(FMLConfig.java:63)
[java.lang.ThreadGroup:uncaughtException:1052]: at net.minecraftforge.fml.loading.FMLServiceProvider.initialize(FMLServiceProvider.java:67)
[java.lang.ThreadGroup:uncaughtException:1052]: at cpw.mods.modlauncher.TransformationServiceDecorator.onInitialize(TransformationServiceDecorator.java:68)
[java.lang.ThreadGroup:uncaughtException:1052]: at cpw.mods.modlauncher.TransformationServicesHandler.lambda$initialiseTransformationServices$7(TransformationServicesHandler.java:107)
[java.lang.ThreadGroup:uncaughtException:1052]: at java.util.HashMap$Values.forEach(HashMap.java:982)
[java.lang.ThreadGroup:uncaughtException:1052]: at cpw.mods.modlauncher.TransformationServicesHandler.initialiseTransformationServices(TransformationServicesHandler.java:107)
[java.lang.ThreadGroup:uncaughtException:1052]: at cpw.mods.modlauncher.TransformationServicesHandler.initializeTransformationServices(TransformationServicesHandler.java:59)
[java.lang.ThreadGroup:uncaughtException:1052]: at cpw.mods.modlauncher.Launcher.run(Launcher.java:76)
[java.lang.ThreadGroup:uncaughtException:1052]: at cpw.mods.modlauncher.Launcher.main(Launcher.java:66)
[java.lang.ThreadGroup:uncaughtException:1052]: at net.minecraftforge.server.ServerMain$Runner.runLauncher(ServerMain.java:49)
[java.lang.ThreadGroup:uncaughtException:1052]: at net.minecraftforge.server.ServerMain$Runner.access$100(ServerMain.java:46)
[java.lang.ThreadGroup:uncaughtException:1052]: at net.minecraftforge.server.ServerMain.main(ServerMain.java:43)
[java.lang.ThreadGroup:uncaughtException:1061]: Caused by: java.nio.file.AccessDeniedException: /AMP/Minecraft/config/fml.toml
[java.lang.ThreadGroup:uncaughtException:1061]: at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84)
[java.lang.ThreadGroup:uncaughtException:1061]: at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102)
[java.lang.ThreadGroup:uncaughtException:1061]: at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107)
[java.lang.ThreadGroup:uncaughtException:1061]: at sun.nio.fs.UnixFileSystemProvider.newByteChannel(UnixFileSystemProvider.java:214)
[java.lang.ThreadGroup:uncaughtException:1061]: at java.nio.file.spi.FileSystemProvider.newOutputStream(FileSystemProvider.java:434)
[java.lang.ThreadGroup:uncaughtException:1061]: at java.nio.file.Files.newOutputStream(Files.java:216)
[java.lang.ThreadGroup:uncaughtException:1061]: at com.electronwill.nightconfig.core.io.ConfigWriter.write(ConfigWriter.java:87)
[java.lang.ThreadGroup:uncaughtException:1061]: … 16 more
Console
18:54:39
Exception in thread “main”
