Startup Issue with Minecraft - Previously working world no longer starts
Product AMP ‘Deimos’ v2.7.2.0 (Mainline)
The server was working normally before. Nobody played on it for some time and I did not modify anything. I did not update plugins, change the world, edit configuration files, or install anything.
When I started the server again, it suddenly failed to load the world.
I tested:
  • Paper 26.1.2 and 26.2
  • Java 25
  • Safe mode (–safeMode)
  • Starting with 0 plugins
  • Restoring level.dat from a backup
The problem remains the same.
The server always fails with:
java.lang.IllegalStateException: Overworld settings missing
and
Unable to read or access the world gen settings file.
  • Leave the server offline for some time.
  • Start the server without changing any files, plugins, or configuration.
  • The server fails to start with “Overworld settings missing”.
Check under configuration, updates and make sure it’s using Java 10
