Startup Issue with Minecraft - mods getting automatically disabled
Virtualization QEMU_KVM
I want to use the mods but the server is automatically disabling them due to them being client sided and want to know how to turn that off?
  • installed everything I needed for an rlcraft server
  • mods are getting automatically disabled because they are client sided
  • want to use the mods and don’t know how to disable that
That’s fine, you can still join with the mods and use them, since they’re client-side only.
Client-side mods just can’t load on the server since they’ll crash from missing dependencies.
Most client-side mods are poorly written, so you often need to remove them manually too if the server is crashing due to client-side mods being present.
