Field
Value
Operating System
Linux - Debian GNU/Linux 11 on x86_64
Product
AMP ‘Decadeus’ v2.4.6.8 (Mainline)
Virtualization
QEMU_KVM
Application
Minecraft
Module
MinecraftModule
Running in Container
No
Current State
Ready
mods installed client installed at the correct version of the mods 1.20.1 installed curseforge on my pc with the mods installed on curseforge on my pc but when trying to get into the server it fails and says username issue or time out ext
made server
added mods
cant load into world
This is probably your issue:
Forge Frequently Asked Questions
How do I run Forge using: start.sh/start.bat?
No need! AMP handles all that for you. Just select the version of Forge you’ll need, hit update, and start your server.
Where do I put custom start up arguments?
You can find this options under:
Configuration → Minecraft → Java and Memory → Additional java options
I installed a modpack using AMP’s FTB downloader, why did it start in Vanilla? or The update manager reported a successful update, but ./Minecraft/minecr…
If not, take a read through the rest of the FAQ and upload your logs if you’re still having issues.
Timeout’s on the otherhand are common with modded, just reconnect.
