| Operating System | Windows - Windows 11 Pro on x86_64 |
| Product | AMP ‘Decadeus’ v2.4.6.4 (Mainline) |
| Virtualization | None |
| Application | Minecraft |
| Module | MinecraftModule |
| Running in Container | No |
| Current State | Failed |
I need help, as this is an issue preventing my server from starting normally!
This is because it does not exist, and will not because the version I am running is 1.20.1. I don’t know how to fix this, as there is no such thing as a “ForgeMod.jar” for 1.20.1, and I don’t want to go “Googling” for a random jar from the internet as a crutch of a fix…
I can include logs, etc. but this should be a pretty obvious issue and hopefully a pretty obvious fix… (change the AMP launch panel to run the “run.bat” instead of the ForgeMod.jar on certain MC versions).
I look forward to a reply,
//TheModdersDen
- Create a Minecraft server in the AMP Instance Manager
- Set the server type to Forge
- Change the server Forge version to 47.2.0 and update it.
- Try to start the server. Issue presents itself here…
