Startup Issue with Minecraft - killed by user
the message is “killed by user”
  • run minecraft to first time
  • change to forge
  • add a folder named mods
  • add mods in the folder
  • try to run and crashed
You’ll have to read the console/log to know what happened
Console
3:10:30
at net.minecraft.server.Main.main(Main.java:166) ~[server-1.20.1-20230612.114412-srg.jar%23223!/:?] {re:classloading}
at jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103) ~[?:?] {}
at java.lang.reflect.Method.invoke(Method.java:580) ~[?:?] {}
at net.minecraftforge.fml.loading.targets.CommonLaunchHandler.runTarget(CommonLaunchHandler.java:111) ~[fmlloader-1.20.1-47.3.0.jar%2369!/:?] {}
at net.minecraftforge.fml.loading.targets.CommonLaunchHandler.serverService(CommonLaunchHandler.java:103) ~[fmlloader-1.20.1-47.3.0.jar%2369!/:?] {}
at net.minecraftforge.fml.loading.targets.CommonServerLaunchHandler.lambda$makeService$0(CommonServerLaunchHandler.java:27) ~[fmlloader-1.20.1-47.3.0.jar%2369!/:?] {}
at cpw.mods.modlauncher.LaunchServiceHandlerDecorator.launch(LaunchServiceHandlerDecorator.java:30) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.LaunchServiceHandler.launch(LaunchServiceHandler.java:53) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.LaunchServiceHandler.launch(LaunchServiceHandler.java:71) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.Launcher.run(Launcher.java:108) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.Launcher.main(Launcher.java:78) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.BootstrapLaunchConsumer.accept(BootstrapLaunchConsumer.java:26) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.modlauncher.BootstrapLaunchConsumer.accept(BootstrapLaunchConsumer.java:23) ~[modlauncher-10.0.9.jar%2355!/:?] {}
at cpw.mods.bootstraplauncher.BootstrapLauncher.main(BootstrapLauncher.java:141) ~[bootstraplauncher-1.1.2.jar:?] {}
main/WARN
3:10:30
Could not decode GlobalLootModifier with json id nethersdelight:chopping_string - error: Unknown type ‘minecraft:alternative’
Could not decode GlobalLootModifier with json id domesticationinnovation:blazing_enchanted_book - error: Not a JSON object: null
Not all defined tags for registry ResourceKey[minecraft:root / minecraft:worldgen/biome]: are present in data pack: minecraft:is_plains
main/INFO
3:10:39
Applied 7 data villager trades
Finished additional setup in 0 ms
Server thread/INFO
3:10:40
Starting minecraft server version 1.20.1
Loading properties
Default game type: SURVIVAL
Generating keypair
Starting Minecraft server on 0.0.0.0:25566
Using epoll channel type
Loading JourneyMap Forge Configs
Thread-4/INFO
3:10:40
Server thread/INFO
3:10:41
Loading server configs…
Added to village structure pool
Preparing level “world”
3:10:52
Preparing start region for dimension minecraft:overworld
3:11:00
Time elapsed: 8027 ms
Done (19.338s)! For help, type “help”
Successfully initialized permission handler forge:default_handler
Netty Epoll Server IO #1/INFO
3:11:02
Disconnecting Player (server is still starting): literal{Server is still starting! Please wait before reconnecting.}
Server thread/INFO
3:11:08
Loaded config for: lootintegrations.json
Make sure that you are using Java 17 for Forge 1.20.1
