| Operating System | Linux - Ubuntu 20.04.6 on x86_64 |
| Product | AMP ‘Phobos’ v2.6.0.2 (Mainline) |
| Virtualization | QEMU_KVM |
| Application | Minecraft |
| Module | MinecraftModule |
| Running in Container | No |
| Current State | Failed |
After installing the GTNH server file and setting up the server for an expected correct startup, a JAVA error is thrown. Lack of knowledges makes me unable to find & fix the issue.
- Install GTNH 2.7.0 Beta3 Java 17-21 server files.
- Configure server for launch
- Attempt to start the server
Consoles log:
at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:118)
at java.base/java.lang.reflect.Method.invoke(Method.java:580)
at me.eigenraven.lwjgl3ify.rfb.entry.ServerMain.run(ServerMain.java:37)
at me.eigenraven.lwjgl3ify.rfb.entry.ServerMain.main(ServerMain.java:12)
Caused by: java.lang.IllegalStateException: System classloader not overwritten, add -Djava.system.class.loader=com.gtnewhorizons.retrofuturabootstrap.RfbSystemClassLoader to your JVM flags
at com.gtnewhorizons.retrofuturabootstrap.Main.main(Main.java:140)
at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103)
... 3 more
EDIT 1:
After adding the Java argument from the server files to the AMP configuration, I am getting a new error.
Here are the JAVA argument:
java -Xms6G -Xmx6G -Dfml.readTimeout=180 @java9args.txt -jar lwjgl3ify-forgePatches.jar nogui
The new error:
[0.063s][warning][cds] Archived non-system classes are disabled because the java.system.class.loader property is specified (value = "com.gtnewhorizons.retrofuturabootstrap.RfbSystemClassLoader"). To use archived non-system classes, this property must not be set
Error occurred during initialization of VM
java.lang.Error: com.gtnewhorizons.retrofuturabootstrap.RfbSystemClassLoader
at java.lang.ClassLoader.initSystemClassLoader(java.base@21.0.4/ClassLoader.java:2024)
at java.lang.System.initPhase3(java.base@21.0.4/System.java:2333)
Caused by: java.lang.ClassNotFoundException: com.gtnewhorizons.retrofuturabootstrap.RfbSystemClassLoader
at jdk.internal.loader.BuiltinClassLoader.loadClass(java.base@21.0.4/BuiltinClassLoader.java:641)
at jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(java.base@21.0.4/ClassLoaders.java:188)
at java.lang.ClassLoader.loadClass(java.base@21.0.4/ClassLoader.java:526)
at java.lang.Class.forName0(java.base@21.0.4/Native Method)
at java.lang.Class.forName(java.base@21.0.4/Class.java:534)
at java.lang.Class.forName(java.base@21.0.4/Class.java:513)
at java.lang.ClassLoader.initSystemClassLoader(java.base@21.0.4/ClassLoader.java:2010)
