Startup Issue with Minecraft - infinite startup after server upgrade
Current State Starting
It has been appx 30m
  • upgrade server while it was running
  • Wait for panel to come online
  • Start server
Sometimes when modded servers are stopped abruptly some config data can be corrupted (the server is stopped during the update process (should be a graceful stop in most cases, but modded can be a bit finicky).
If you try to start the server a couple times and it just gets stuck you might want to delete the configs folder and re-import them over SFTP.
In the future I’d recommend making sure the server is fully stopped before running any updates.
Yes, should be a graceful stop, but I noticed the server gets killed. See AMP doesn't stop instances/applications properly · Issue #1019 · CubeCoders/AMP · GitHub
