Startup Issue with Minecraft - I'm trying to mod Minecraft it wont run
I’m trying to mode my server with the modpack all the mods 10. every time i think ive added the mods correctly and go to test if i did it correct it seems to crash. I’m use sftp to add the list of .jar files in the mod pack but it seems to not want to launch the server i have the correct Neoforge version the modpack is made for. i see its failing in the console i just don’t know how to fix it
  • im creating a new instance.
  • adding a mods folder in the file browse
  • using sftp to add the .jar files from the modpack from my forge profile
  • before i added the mod file i set the server to the neoforge version required for the modpack
  • i hit the update button
  • hit launch it thinks it over for afew seconds then in the console it says failed to strart
Make sure you have Java 21 selected
java version 21 was the default
in the console it gives thiss error what are the steps to solve this?
net.neoforged.fml.ModLoadingException: Loading errors encountered:
- Iris (iris) has failed to load correctly
java.lang.RuntimeException: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER
- Lighty (lighty) has failed to load correctly
java.lang.NoClassDefFoundError: net/minecraft/client/OptionInstance$ValueSet
- Sodium (sodium) has failed to load correctly
java.lang.BootstrapMethodError: java.lang.RuntimeException: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER
- Extreme Sound Muffler (extremesoundmuffler) has failed to load correctly
java.lang.IllegalArgumentException: class com.leobeliik.extremesoundmuffler.SoundMufflerNeoForge has no @SubscribeEvent methods, but register was called anyway.
The event bus only recognizes listener methods that have the @SubscribeEvent annotation.
- Euphoria Patcher (euphoria_patcher) has failed to load correctly
java.lang.NoClassDefFoundError: org/apache/commons/compress/compressors/CompressorException
You’re trying to load client-only mods on the server.
You need to use the ATM10 server pack, don’t just upload your client mods.
(the server pack is under the Additonal Files section on CurseForge)
