Startup Issue with Minecraft - Im having problems with using a custom startup setting
Current State Installing
Custom startup arguments
For use only with the ‘Custom’ server type. Add {JarFile} to insert the selected jar file, and {Memory} for the selected memory limit
When specifying custom installation type i see this window. I am not sure how to specify the config parameters. I have uplaoded custom server jar to the file manager as server.jar and when im trying to run it the server stops in >5 seconds. what would be the correct way to set up a custom server installation?
  • set up the server installation to custom
  • tried setting the custom config parameters
  • added server.jar (Custom jar) as the preferred server bootup jar file
