Startup Issue with Minecraft - he Minecraft server stopped within 5 seconds of starting,
Operating System Linux - Ubuntu 26.04.1 on x86_64
he Minecraft server stopped within 5 seconds of starting, this is not a fault with AMP - you should check your Minecraft ser
vers log files to find out why it is unable to start.
am using papermc Server Type
  • click start
  • The failure msg
  • failed to start
Read what you put under the “Issue” section again and follow its advice. Post the logs here
