| Operating System | Linux - Ubuntu 24.04.3 on x86_64 |
| Product | AMP ‘Phobos’ v2.6.4.2 (Mainline) |
| Virtualization | None |
| Application | Minecraft |
| Module | MinecraftModule |
| Running in Container | No |
| Current State | Failed |
at TRANSFORMER/minecraft@1.20.1/net.minecraft.commands.BrigadierExceptions.(BrigadierExceptions.java:24) this is one of the common logs but doesn’t seem to give more details.
main/WARN
22:51:04
Reference map 'cristellib-forge-refmap.json' for cristellib.mixins.json could not be read. If this is a development environment you can ignore this message
Reference map ‘mixins.luminous_halloween.refmap.json’ for mixins.luminous_halloween.json could not be read. If this is a development environment you can ignore this message
Reference map ‘integrated_cataclysm.refmap.json’ for integrated_cataclysm.mixins.json could not be read. If this is a development environment you can ignore this message
Reference map ‘trashslot.refmap.json’ for trashslot.mixins.json could not be read. If this is a development environment you can ignore this message
Reference map ‘mes-forge-refmap.json’ for mes-forge.mixins.json could not be read. If this is a development environment you can ignore this message
Reference map ‘coroutil.refmap.json’ for coroutil.mixins.json could not be read. If this is a development environment you can ignore this message
Reference map ‘moblassos.refmap.json’ for moblassos.common.mixins.json could not be read. If this is a development environment you can ignore this message
main/INFO
22:51:05
Patching IForgeItemStack#getEnchantmentLevel
main/ERROR
22:51:05
Attempted to load class net/minecraft/client/MouseHandler for invalid dist DEDICATED_SERVER
main/WARN
22:51:05
Error loading class: net/minecraft/client/MouseHandler (java.lang.RuntimeException: Attempted to load class net/minecraft/client/MouseHandler for invalid dist DEDICATED_SERVER)
@Mixin target net.minecraft.client.MouseHandler was not found fabric-screen-api-v1.mixins.json:MouseMixin
main/ERROR
22:51:05
Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER
main/WARN
22:51:05
Error loading class: net/minecraft/client/gui/screens/Screen (java.lang.RuntimeException: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER)
@Mixin target net.minecraft.client.gui.screens.Screen was not found fabric-screen-api-v1.mixins.json:ScreenAccessor
Error loading class: net/mehvahdjukaar/amendments/events/behaviors/InteractEvents (java.lang.ClassNotFoundException: net.mehvahdjukaar.amendments.events.behaviors.InteractEvents)
@Mixin target net.mehvahdjukaar.amendments.events.behaviors.InteractEvents was not found mynethersdelight.mixins.json:amendments.InteractEventsMixin
22:51:06
Error loading class: com/aetherteam/aether_genesis/world/GenesisRegion (java.lang.ClassNotFoundException: com.aetherteam.aether_genesis.world.GenesisRegion)
main/INFO
22:51:06
Loaded config for: structureessentials.json
main/ERROR
22:51:06
main/WARN
22:51:06
@Mixin target net.minecraft.client.gui.screens.Screen was not found relics.mixins.json:ScreenMixin
Error loading class: dev/tr7zw/skinlayers/render/CustomizableModelPart (java.lang.ClassNotFoundException: dev.tr7zw.skinlayers.render.CustomizableModelPart)
Error loading class: net/minecraft/client/model/geom/builders/LayerDefinition (java.lang.ClassNotFoundException: net.minecraft.client.model.geom.builders.LayerDefinition)
@Mixin target net.minecraft.client.model.geom.builders.LayerDefinition was not found aether_protect_your_moa.mixins.json:client.accessor.LayerDefinitionAccessor
Error loading class: com/aetherteam/aether_genesis/block/natural/GreenAercloudBlock (java.lang.ClassNotFoundException: com.aetherteam.aether_genesis.block.natural.GreenAercloudBlock)
@Mixin target com.aetherteam.aether_genesis.block.natural.GreenAercloudBlock was not found aether_redux.mixins.json:common.block.GreenAercloudBlockMixin
Error loading class: com/aetherteam/aether_genesis/block/natural/OrangeTreeBlock (java.lang.ClassNotFoundException: com.aetherteam.aether_genesis.block.natural.OrangeTreeBlock)
@Mixin target com.aetherteam.aether_genesis.block.natural.OrangeTreeBlock was not found aether_redux.mixins.json:common.block.OrangeTreeMixin
Error loading class: com/aetherteam/aether_genesis/block/natural/PurpleAercloudBlock (java.lang.ClassNotFoundException: com.aetherteam.aether_genesis.block.natural.PurpleAercloudBlock)
@Mixin target com.aetherteam.aether_genesis.block.natural.PurpleAercloudBlock was not found aether_redux.mixins.json:common.block.PurpleAercloudBlockMixin
Error loading class: net/minecraft/client/renderer/entity/PhantomRenderer (java.lang.ClassNotFoundException: net.minecraft.client.renderer.entity.PhantomRenderer)
@Mixin target net.minecraft.client.renderer.entity.PhantomRenderer was not found mixins.deeperdarker.json:PhantomRendererMixin
Error loading class: tschipp/carryon/common/carry/PickupHandler (java.lang.ClassNotFoundException: tschipp.carryon.common.carry.PickupHandler)
@Mixin target tschipp.carryon.common.carry.PickupHandler was not found fossil_forge.mixins.json:PickupHandlerMixin
Error loading class: vazkii/botania/common/item/equipment/armor/manasteel/ManasteelArmorItem (java.lang.ClassNotFoundException: vazkii.botania.common.item.equipment.armor.manasteel.ManasteelArmorItem)
@Mixin target vazkii.botania.common.item.equipment.armor.manasteel.ManasteelArmorItem was not found aether_gloves_for_all.mixins.json:ManasteelArmorItemMixin
Error loading class: blusunrize/immersiveengineering/api/wires/GlobalWireNetwork (java.lang.ClassNotFoundException: blusunrize.immersiveengineering.api.wires.GlobalWireNetwork)
@Mixin target blusunrize.immersiveengineering.api.wires.GlobalWireNetwork was not found mixins.epp.json:MixinGlobalWireNetwork
Error loading class: net/darkhax/darkutils/features/charms/CharmEffects (java.lang.ClassNotFoundException: net.darkhax.darkutils.features.charms.CharmEffects)
Error loading class: com/brandon3055/csg/ModEventHandler (java.lang.ClassNotFoundException: com.brandon3055.csg.ModEventHandler)
Error loading class: vazkii/quark/content/tweaks/module/AutomaticRecipeUnlockModule (java.lang.ClassNotFoundException: vazkii.quark.content.tweaks.module.AutomaticRecipeUnlockModule)
main/ERROR
22:51:06
Attempted to load class com/mojang/blaze3d/vertex/BufferBuilder$RenderedBuffer for invalid dist DEDICATED_SERVER
main/WARN
22:51:06
Error loading class: com/mojang/blaze3d/vertex/BufferBuilder$RenderedBuffer (java.lang.RuntimeException: Attempted to load class com/mojang/blaze3d/vertex/BufferBuilder$RenderedBuffer for invalid dist DEDICATED_SERVER)
main/ERROR
22:51:06
main/WARN
22:51:06
main/ERROR
22:51:07
Attempted to load class com/mojang/blaze3d/vertex/PoseStack$Pose for invalid dist DEDICATED_SERVER
main/WARN
22:51:07
Error loading class: com/mojang/blaze3d/vertex/PoseStack$Pose (java.lang.RuntimeException: Attempted to load class com/mojang/blaze3d/vertex/PoseStack$Pose for invalid dist DEDICATED_SERVER)
Error loading class: com/mojang/blaze3d/platform/InputConstants$Key (java.lang.ClassNotFoundException: com.mojang.blaze3d.platform.InputConstants$Key)
main/INFO
22:51:07
Initializing MixinExtras via com.llamalad7.mixinextras.service.MixinExtrasServiceImpl(version=0.5.0).
[java.lang.ThreadGroup:uncaughtException:1077]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.LaunchServiceHandler.launch(LaunchServiceHandler.java:71)
[java.lang.ThreadGroup:uncaughtException:1077]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.Launcher.run(Launcher.java:108)
[java.lang.ThreadGroup:uncaughtException:1077]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.Launcher.main(Launcher.java:78)
[java.lang.ThreadGroup:uncaughtException:1077]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.BootstrapLaunchConsumer.accept(BootstrapLaunchConsumer.java:26)
[java.lang.ThreadGroup:uncaughtException:1077]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.BootstrapLaunchConsumer.accept(BootstrapLaunchConsumer.java:23)
[java.lang.ThreadGroup:uncaughtException:1077]: at cpw.mods.bootstraplauncher@1.1.2/cpw.mods.bootstraplauncher.BootstrapLauncher.main(BootstrapLauncher.java:141)
[java.lang.ThreadGroup:uncaughtException:1086]: Caused by: java.lang.reflect.InvocationTargetException
[java.lang.ThreadGroup:uncaughtException:1086]: at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java.lang.ThreadGroup:uncaughtException:1086]: at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
[java.lang.ThreadGroup:uncaughtException:1086]: at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[java.lang.ThreadGroup:uncaughtException:1086]: at java.base/java.lang.reflect.Method.invoke(Method.java:569)
[java.lang.ThreadGroup:uncaughtException:1086]: at MC-BOOTSTRAP/fmlloader@1.20.1-47.4.10/net.minecraftforge.fml.loading.targets.CommonLaunchHandler.runTarget(CommonLaunchHandler.java:111)
[java.lang.ThreadGroup:uncaughtException:1086]: at MC-BOOTSTRAP/fmlloader@1.20.1-47.4.10/net.minecraftforge.fml.loading.targets.CommonLaunchHandler.serverService(CommonLaunchHandler.java:103)
[java.lang.ThreadGroup:uncaughtException:1086]: at MC-BOOTSTRAP/fmlloader@1.20.1-47.4.10/net.minecraftforge.fml.loading.targets.CommonServerLaunchHandler.lambda$makeService$0(CommonServerLaunchHandler.java:27)
[java.lang.ThreadGroup:uncaughtException:1086]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.LaunchServiceHandlerDecorator.launch(LaunchServiceHandlerDecorator.java:30)
[java.lang.ThreadGroup:uncaughtException:1086]: … 7 more
[java.lang.Throwable:printStackTrace:659]: Caused by: java.lang.ExceptionInInitializerError
[java.lang.Throwable:printStackTrace:659]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.network.chat.MutableComponent.m_237204_(MutableComponent.java:29)
[java.lang.Throwable:printStackTrace:659]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.network.chat.Component.m_237115_(Component.java:444)
[java.lang.Throwable:printStackTrace:659]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.commands.BrigadierExceptions.(BrigadierExceptions.java:24)
[java.lang.Throwable:printStackTrace:659]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.SharedConstants.(SharedConstants.java:216)
[java.lang.Throwable:printStackTrace:659]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.server.Main.main(Main.java:69)
[java.lang.Throwable:printStackTrace:659]: … 15 more
[java.lang.Throwable:printStackTrace:682]: Caused by: java.lang.RuntimeException: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER
[java.lang.Throwable:printStackTrace:682]: at MC-BOOTSTRAP/fmlloader@1.20.1-47.4.10/net.minecraftforge.fml.loading.RuntimeDistCleaner.processClassWithFlags(RuntimeDistCleaner.java:57)
[java.lang.Throwable:printStackTrace:682]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.LaunchPluginHandler.offerClassNodeToPlugins(LaunchPluginHandler.java:88)
[java.lang.Throwable:printStackTrace:682]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.ClassTransformer.transform(ClassTransformer.java:120)
[java.lang.Throwable:printStackTrace:682]: at MC-BOOTSTRAP/cpw.mods.modlauncher@10.0.9/cpw.mods.modlauncher.TransformingClassLoader.maybeTransformClassBytes(TransformingClassLoader.java:50)
[java.lang.Throwable:printStackTrace:682]: at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.readerToClass(ModuleClassLoader.java:113)
[java.lang.Throwable:printStackTrace:682]: at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.lambda$findClass$15(ModuleClassLoader.java:219)
[java.lang.Throwable:printStackTrace:682]: at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.loadFromModule(ModuleClassLoader.java:229)
[java.lang.Throwable:printStackTrace:682]: at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.findClass(ModuleClassLoader.java:219)
[java.lang.Throwable:printStackTrace:682]: at cpw.mods.securejarhandler/cpw.mods.cl.ModuleClassLoader.loadClass(ModuleClassLoader.java:135)
[java.lang.Throwable:printStackTrace:682]: at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:525)
[java.lang.Throwable:printStackTrace:682]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.resources.ResourceLocation.handler$cjh000$etf$illegalPathOverride(ResourceLocation.java:525)
[java.lang.Throwable:printStackTrace:682]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.resources.ResourceLocation.m_135841_(ResourceLocation.java:206)
[java.lang.Throwable:printStackTrace:682]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.resources.ResourceLocation.m_245185_(ResourceLocation.java:241)
[java.lang.Throwable:printStackTrace:682]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.resources.ResourceLocation.(ResourceLocation.java:40)
[java.lang.Throwable:printStackTrace:682]: at TRANSFORMER/minecraft@1.20.1/net.minecraft.network.chat.Style.(Style.java:39)
[java.lang.Throwable:printStackTrace:682]: … 20 more
Console
22:51:08
Exception in thread "main"
- Press start to start server.
- wait for server to load and go through its setup
- server doesn’t load
