Make sure you have the Sever Type set to Forge, and the correct Forge version selected in AMP. (and the Jar set to Autoselect)
From there hit Download/Update and see if that works. If not, stop/start the instance from the main panel and see if that kicks it over.
The King himself saves another victim, I was snooping around looking for answers and I did manage to find the switch to forge fix but it didn’t work until you good sir said to try the “stop/start the instance from the main panel” Appreciate it!
