| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Failed |
I have been using a specific instance for the past month that randomly started not letting me log into the server and I could not find any solutions on Google. I downloaded the world file and created a fresh instance to fix the issue but now every time I make an instance and add my world file and modpack (which all have worked without issues for the past month) now suddenly cannot load. The error message is that the files from Forge specifically (not the modpack but Forge itself) are missing files. The only solution I have found on Google is to remove mods from the modpack, but the modpack worked fine beforehand and works fine on single player. How to I add those missing forge files without breaking things more??
[19Dec2024 23:25:15.304] [main/INFO] [cpw.mods.modlauncher.Launcher/MODLAUNCHER]: ModLauncher running: args [–launchTarget, forgeserver, --fml.forgeVersion, 47.3.7, --fml.mcVersion, 1.20.1, --fml.forgeGroup, net.minecraftforge, --fml.mcpVersion, 20230612.114412]
[19Dec2024 23:25:15.308] [main/INFO] [cpw.mods.modlauncher.Launcher/MODLAUNCHER]: ModLauncher 10.0.9+10.0.9+main.dcd20f30 starting: java version 21.0.4 by Eclipse Adoptium; OS Linux arch amd64 version 6.1.0-26-cloud-amd64
[19Dec2024 23:25:16.528] [main/INFO] [net.minecraftforge.fml.loading.ImmediateWindowHandler/]: ImmediateWindowProvider not loading because launch target is forgeserver
[19Dec2024 23:25:16.572] [main/INFO] [mixin/]: SpongePowered MIXIN Subsystem Version=0.8.5 Source=union:/AMP/Minecraft/libraries/org/spongepowered/mixin/0.8.5/mixin-0.8.5.jar%2365!/ Service=ModLauncher Env=SERVER
[19Dec2024 23:25:17.116] [main/WARN] [net.minecraftforge.fml.loading.moddiscovery.ModFileParser/LOADING]: Mod file /AMP/Minecraft/libraries/net/minecraftforge/fmlcore/1.20.1-47.3.7/fmlcore-1.20.1-47.3.7.jar is missing mods.toml file
[19Dec2024 23:25:17.117] [main/WARN] [net.minecraftforge.fml.loading.moddiscovery.ModFileParser/LOADING]: Mod file /AMP/Minecraft/libraries/net/minecraftforge/javafmllanguage/1.20.1-47.3.7/javafmllanguage-1.20.1-47.3.7.jar is missing mods.toml file
[19Dec2024 23:25:17.119] [main/WARN] [net.minecraftforge.fml.loading.moddiscovery.ModFileParser/LOADING]: Mod file /AMP/Minecraft/libraries/net/minecraftforge/lowcodelanguage/1.20.1-47.3.7/lowcodelanguage-1.20.1-47.3.7.jar is missing mods.toml file
[19Dec2024 23:25:17.120] [main/WARN] [net.minecraftforge.fml.loading.moddiscovery.ModFileParser/LOADING]: Mod file /AMP/Minecraft/libraries/net/minecraftforge/mclanguage/1.20.1-47.3.7/mclanguage-1.20.1-47.3.7.jar is missing mods.toml file
[19Dec2024 23:25:17.840] [main/WARN] [net.minecraftforge.jarjar.selection.JarSelector/]: Attempted to select two dependency jars from JarJar which have the same identification: Mod File: and Mod File: . Using Mod File:
[19Dec2024 23:25:17.843] [main/WARN] [net.minecraftforge.jarjar.selection.JarSelector/]: Attempted to select a dependency jar for JarJar which was passed in as source: cloth_config. Using Mod File: /AMP/Minecraft/mods/cloth-config-11.1.136-forge.jar
[19Dec2024 23:25:17.844] [main/WARN] [net.minecraftforge.jarjar.selection.JarSelector/]: Attempted to select a dependency jar for JarJar which was passed in as source: curios. Using Mod File: /AMP/Minecraft/mods/curios-forge-5.11.0+1.20.1.jar
[19Dec2024 23:25:17.845] [main/INFO] [net.minecraftforge.fml.loading.moddiscovery.JarInJarDependencyLocator/]: Found 62 dependencies adding them to mods collection
- Made new instance
- Loaded server without mods, works
- Add modpack (which worked previously), server doesn’t start
