Startup Issue with Minecraft - Forge and Thermos issues
Installed forge 1.7.10 and desired mods which work, imported world that works aswell, Attempted to add Thermos which doesnt work and if I attempt to run the thermos as server/startup jar file it crashes on start up with no console log other than
A problem occurred running the Server launcher.
Attempted to use the AI but the steps there just repeat themselves with no help to this issue.
  • Installed forge with mods that worked
  • Attempted to add Thermos which doesnt work now
  • Running the server jar other than forge causes a crash
  • A problem occurred running the Server launcher.
Thermos should work fine, make sure you have Java 8 selected under Java and Memory
