Startup Issue with Minecraft - "FAILED TO BIND TO PORT!"
Virtualization QEMU_KVM
Every time I attempt to launch the server it claims that a server is already running on the port.
  • Start Server
  • Server fails to start, reports that the port is in use.
  • Try to restart, fail anyway.
Have you checked to see if anything else is running on that port? Perhaps a previous attempt to set up a MC server?
Using a host, so I’m not sure. I’ve shut down and restarted the VPS completely, not sure what it could be.
Run ss -l -t | grep 25565 (assuming your MC server is on that port) to see if something is using it.
Could also be the possibility that sleep mode was active during a scheduled restart, which would lock up the port.
Fix for that is to stop/start the instance, then change the schedule to remove the scheduled restart.
