Startup Issue with Minecraft - even after acepting eula is not starting 1st time
why error message for 1st start? server stoped after 5 second
The Minecraft server stopped within 5 seconds of starting, this is not a fault with AMP - you should check your Minecraft servers log files to find out why it is unable to start.
  • accepted eula
  • hit start button
  • receive error message 1st time
Likely because minecraft 26.1 uses a new version of Java which isn’t set by default.
This should fix it and worked for me.
  1. Update the minecraft instance itself
    • Either through Support and updates > “Update This Instance”…
    • Or in the list of instances click “Update Instance” on it.
  2. Inside the instance, go to Configuration > Minecraft > “Java and Memory” tab
  3. Under “Java Version”
    • If it’s set to “TEMURIN 25”, Switch it to 21, then back to 25, and restart the instance. That fixed it for me.
    • If it’s not already set to 25, try setting it to 25. If you don’t see that as an option try the “Scan for Java Installs” button.
