Startup Issue with Minecraft - Error when starting server with forge
Virtualization QEMU_KVM
When I try to start the server with forge i get an error:
Console18:35:28
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at net.minecraftforge.fml.relauncher.ServerLaunchWrapper.run(ServerLaunchWrapper.java:70)
at net.minecraftforge.fml.relauncher.ServerLaunchWrapper.main(ServerLaunchWrapper.java:34)
Caused by: java.lang.ClassCastException: class jdk.internal.loader.ClassLoaders$AppClassLoader cannot be cast to class java.net.URLClassLoader (jdk.internal.loader.ClassLoaders$AppClassLoader and java.net.URLClassLoader are in module java.base of loader ‘bootstrap’)
at net.minecraft.launchwrapper.Launch.(Launch.java:34)
at net.minecraft.launchwrapper.Launch.main(Launch.java:28)
… 6 more
  • Choose forge 1.12.2
  • Install forge 1.12.2 at server
  • Start the server/instance
You’ve got the wrong Java version selected. Pick the version that is appropriate for the given server type.
I have installed version 8 and now another error appears:
0:22:31
... 11 more
Caused by: java.lang.NullPointerException
at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:182) ~[launchwrapper-1.12.jar:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:418) ~[?:1.8.0_292]
at java.lang.ClassLoader.loadClass(ClassLoader.java:351) ~[?:1.8.0_292]
at java.lang.ClassLoader.defineClass1(Native Method) ~[?:1.8.0_292]
at java.lang.ClassLoader.defineClass(ClassLoader.java:756) ~[?:1.8.0_292]
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142) ~[?:1.8.0_292]
at java.net.URLClassLoader.defineClass(URLClassLoader.java:468) ~[?:1.8.0_292]
at java.net.URLClassLoader.access$100(URLClassLoader.java:74) ~[?:1.8.0_292]
at java.net.URLClassLoader$1.run(URLClassLoader.java:369) ~[?:1.8.0_292]
at java.net.URLClassLoader$1.run(URLClassLoader.java:363) ~[?:1.8.0_292]
at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_292]
at java.net.URLClassLoader.findClass(URLClassLoader.java:362) ~[?:1.8.0_292]
at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:117) ~[launchwrapper-1.12.jar:?]
at java.lang.Class.forName0(Native Method) ~[?:1.8.0_292]
at java.lang.Class.forName(Class.java:348) ~[?:1.8.0_292]
at net.minecraftforge.fml.relauncher.CoreModManager.loadCoreMod(CoreModManager.java:527) ~[forge-1.12.2-14.23.5.2860.jar:?]
at net.minecraftforge.fml.relauncher.CoreModManager.discoverCoreMods(CoreModManager.java:451) ~[forge-1.12.2-14.23.5.2860.jar:?]
at net.minecraftforge.fml.relauncher.CoreModManager.handleLaunch(CoreModManager.java:265) ~[forge-1.12.2-14.23.5.2860.jar:?]
at net.minecraftforge.fml.relauncher.FMLLaunchHandler.setupHome(FMLLaunchHandler.java:107) ~[forge-1.12.2-14.23.5.2860.jar:?]
... 11 more
main/INFO
0:22:31
[net.minecraftforge.fml.relauncher.ServerLaunchWrapper:main:34]: java.lang.reflect.InvocationTargetException
[net.minecraftforge.fml.relauncher.ServerLaunchWrapper:main:34]: at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[net.minecraftforge.fml.relauncher.ServerLaunchWrapper:main:34]: at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
[net.minecraftforge.fml.relauncher.ServerLaunchWrapper:main:34]: at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[net.minecraftforge.fml.relauncher.ServerLaunchWrapper:main:34]: at java.lang.reflect.Method.invoke(Method.java:498)
[net.minecraftforge.fml.relauncher.ServerLaunchWrapper:main:34]: at net.minecraftforge.fml.relauncher.ServerLaunchWrapper.run(ServerLaunchWrapper.java:70)
[net.minecraftforge.fml.relauncher.ServerLaunchWrapper:main:34]: at net.minecraftforge.fml.relauncher.ServerLaunchWrapper.main(ServerLaunchWrapper.java:34)
[net.minecraftforge.fml.relauncher.ServerLaunchWrapper:run:75]: Caused by: net.minecraftforge.fml.relauncher.FMLSecurityManager$ExitTrappedException
[net.minecraftforge.fml.relauncher.ServerLaunchWrapper:run:75]: at net.minecraftforge.fml.relauncher.FMLSecurityManager.checkPermission(FMLSecurityManager.java:49)
[net.minecraftforge.fml.relauncher.ServerLaunchWrapper:run:75]: at java.lang.SecurityManager.checkExit(SecurityManager.java:761)
Console
0:22:31
main/INFO
0:22:31
[net.minecraftforge.fml.relauncher.ServerLaunchWrapper:run:75]: at java.lang.Runtime.exit(Runtime.java:107)
[net.minecraftforge.fml.relauncher.ServerLaunchWrapper:run:75]: at java.lang.System.exit(System.java:973)
[net.minecraftforge.fml.relauncher.ServerLaunchWrapper:run:75]: at net.minecraft.launchwrapper.Launch.launch(Launch.java:138)
[net.minecraftforge.fml.relauncher.ServerLaunchWrapper:run:75]: at net.minecraft.launchwrapper.Launch.main(Launch.java:28)
[net.minecraftforge.fml.relauncher.ServerLaunchWrapper:run:75]: ... 6 more
After reading through your errors this doesn’t seem to be an issue with AMP itself; has the server ever worked for you or is this a new set up? Have you made sure in configuration under Java you have the right version selected and path defined as Mike mentioned?
I have created a new instance with Forge (without forge it works).
This are de server settings:
java version: JDK 8
I don’t know if I did some wrong at creation, but I tried 2 times and had the same errors.
Is there a tutorial to add mods with forge to an instance from 0? I was searching but the version of the panel was older than the current one…
I have mods that have biomes, so I would like to add them as soon as the world is generated.
Try a newer Java version.
I have tried all versions and the only one that gives a different error than the one I passed for the first time is version 8.
