| Product | AMP ‘Proteus’ v2.8.0.2 (Mainline) |
| Virtualization | Podman |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Failed |
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x000073788d88da20, pid=86, tid=88
# JRE version: OpenJDK Runtime Environment Temurin-21.0.11+10 (21.0.11+10) (build 21.0.11+10-LTS)
# Java VM: OpenJDK 64-Bit Server VM Temurin-21.0.11+10 (21.0.11+10-LTS, mixed mode, sharing, tiered, compressed oops, compressed class ptrs, g1 gc, linux-amd64)
# Problematic frame:
# V [libjvm.so+0x4d1a20] AccessInternal::PostRuntimeDispatch<G1BarrierSet::AccessBarrier<2383974ul, G1BarrierSet>, (AccessInternal::BarrierType)3, 2383974ul>::oop_access_barrier(oopDesc*, long)+0x0
# Core dump will be written. Default location: Core dumps may be processed with "/usr/share/apport/apport -p%p -s%s -c%c -d%d -P%P -u%u -g%g -F%F -- %E" (or dumping to /AMP/Minecraft/core.86)
# An error report file with more information is saved as:
# /AMP/Minecraft/hs_err_pid86.log
[1.063s][warning][os] Loading hsdis library failed
# If you would like to submit a bug report, please visit:
# https://github.com/adoptium/adoptium-support/issues
this is the error i get then my server goes sleep mode or if i restart.
it fixes kinda when deleting libery.
it’s FTB modpack skies2: Aero
- delete libery
- make new instance
- ask chatGPT
