Startup Issue with Minecraft - does not let the server in
Product AMP ‘Decadeus’ v2.4.7.0 (Mainline)
When you enter it lets you walk for a while (although it does not allow you to interact with the world) and then the message Timeout expired gives an error.
  • the server was working fine
  • suddenly he started taking out and not letting interact
  • even after restarting the error continues
Sounds like a networking issue, I’d suggest checking your home network (or whereever the server is hosted) to see if everything’s all working fine.
Worst case, if you can’t find anything wrong, add the following startup arg to both the client and the server (google how to do it with your launcher, every launcher is different). In AMP you just add it under Java and Memory.
-Dfml.read.Timeout=180
