Startup Issue with Minecraft - Docker Instance cannot start Minecraft Bedrock
Windows Server 2022
local install of Docker and AMP
Current State PreStart
I validated the setup of AMP and Docker by using a JAVA instance. This worked as expected. I then created an instance of Minecraft for Bedrock. This failed once the startup was initiated. log excerpt: [0] (PlatformException) : ApplicationName=‘./Minecraft/bedrock_server’, CommandLine=‘’, CurrentDirectory=‘./Minecraft/’, Native error= Cannot find the specified file. I validated that the file indeed exists in the structure.
  • Installed and setup Docker per the Windows install guidelines and validated it is running correctly with the elevated permissions
  • Updated AMP to most current version same with Instances
  • setup AMP to use Docker for creating instances. followed the Docker Log to see the instance be created in the container and watched the attempt to start the Bedrock_server exe fail
