Startup Issue with Minecraft - Crashes when it starts
Product AMP ‘Callisto’ v2.5.0.6 (Mainline)
The server was fine, I restarted it like I do every 12 hours and from there it doesn’t start anymore, failed to start server. and it doesn’t throw any errors.
[22Apr2024 04:00:26.680] [main/INFO] [cpw.mods.modlauncher.Launcher/MODLAUNCHER]: ModLauncher running: args [–launchTarget, forgeserver, --fml.forgeVersion, 47.2.23, --fml.mcVersion, 1.20.1, --fml.forgeGroup, net.minecraftforge, --fml.mcpVersion, 20230612.114412]
[22Apr2024 04:00:26.684] [main/INFO] [cpw.mods.modlauncher.Launcher/MODLAUNCHER]: ModLauncher 10.0.9+10.0.9+main.dcd20f30 starting: java version 17.0.10 by Eclipse Adoptium; OS Linux arch amd64 version 5.10.0-28-cloud-amd64
[22Apr2024 04:00:28.198] [main/INFO] [net.minecraftforge.fml.loading.ImmediateWindowHandler/]: ImmediateWindowProvider not loading because launch target is forgeserver
[22Apr2024 04:00:28.250] [main/INFO] [mixin/]: SpongePowered MIXIN Subsystem Version=0.8.5 Source=union:/AMP/Minecraft/libraries/org/spongepowered/mixin/0.8.5/mixin-0.8.5.jar%2365!/ Service=ModLauncher Env=SERVER
[22Apr2024 04:00:28.809] [main/WARN] [net.minecraftforge.fml.loading.moddiscovery.ModFileParser/LOADING]: Mod file /AMP/Minecraft/libraries/net/minecraftforge/fmlcore/1.20.1-47.2.23/fmlcore-1.20.1-47.2.23.jar is missing mods.toml file
[22Apr2024 04:00:28.810] [main/WARN] [net.minecraftforge.fml.loading.moddiscovery.ModFileParser/LOADING]: Mod file /AMP/Minecraft/libraries/net/minecraftforge/javafmllanguage/1.20.1-47.2.23/javafmllanguage-1.20.1-47.2.23.jar is missing mods.toml file
[22Apr2024 04:00:28.811] [main/WARN] [net.minecraftforge.fml.loading.moddiscovery.ModFileParser/LOADING]: Mod file /AMP/Minecraft/libraries/net/minecraftforge/lowcodelanguage/1.20.1-47.2.23/lowcodelanguage-1.20.1-47.2.23.jar is missing mods.toml file
[22Apr2024 04:00:28.811] [main/WARN] [net.minecraftforge.fml.loading.moddiscovery.ModFileParser/LOADING]: Mod file /AMP/Minecraft/libraries/net/minecraftforge/mclanguage/1.20.1-47.2.23/mclanguage-1.20.1-47.2.23.jar is missing mods.toml file
[22Apr2024 04:00:29.154] [main/WARN] [net.minecraftforge.jarjar.selection.JarSelector/]: Attempted to select two dependency jars from JarJar which have the same identification: Mod File: and Mod File: . Using Mod File:
[22Apr2024 04:00:29.156] [main/WARN] [net.minecraftforge.jarjar.selection.JarSelector/]: Attempted to select a dependency jar for JarJar which was passed in as source: resourcefullib. Using Mod File: /AMP/Minecraft/mods/resourcefullib-forge-1.20.1-2.1.24.jar
[22Apr2024 04:00:29.156] [main/WARN] [net.minecraftforge.jarjar.selection.JarSelector/]: Attempted to select a dependency jar for JarJar which was passed in as source: apexcore. Using Mod File: /AMP/Minecraft/mods/apexcore-1.20.1-10.0.0.jar
[22Apr2024 04:00:29.156] [main/INFO] [net.minecraftforge.fml.loading.moddiscovery.JarInJarDependencyLocator/]: Found 14 dependencies adding them to mods collection
[22Apr2024 04:00:32.608] [main/INFO] [mixin/]: Compatibility level set to JAVA_17
[22Apr2024 04:00:32.769] [main/ERROR] [mixin/]: Mixin config azurelib.mixins.json does not specify “minVersion” property
[22Apr2024 04:00:32.772] [main/ERROR] [mixin/]: Mixin config azurelib.forge.mixins.json does not specify “minVersion” property
[22Apr2024 04:00:32.844] [main/ERROR] [mixin/]: Mixin config necronomicon.forge.mixins.json does not specify “minVersion” property
[22Apr2024 04:00:32.913] [main/INFO] [mixin/]: Successfully loaded Mixin Connector [com.aizistral.enigmaticlegacy.MixinConnector]
[22Apr2024 04:00:32.917] [main/INFO] [cpw.mods.modlauncher.LaunchServiceHandler/MODLAUNCHER]: Launching target ‘forgeserver’ with arguments
[22Apr2024 04:00:32.960] [main/WARN] [mixin/]: Reference map ‘letsdo-vinery-forge-forge-refmap.json’ for vinery.mixins.json could not be read. If this is a development environment you can ignore this message
[22Apr2024 04:00:32.993] [main/WARN] [mixin/]: Reference map ‘handcrafted-forge-1.20.1-forge-refmap.json’ for handcrafted.mixins.json could not be read. If this is a development environment you can ignore this message
[22Apr2024 04:00:33.021] [main/WARN] [mixin/]: Reference map ‘smallships-forge-refmap.json’ for smallships.mixins.json could not be read. If this is a development environment you can ignore this message
[22Apr2024 04:00:33.031] [main/WARN] [mixin/]: Reference map ‘trashslot.refmap.json’ for trashslot.mixins.json could not be read. If this is a development environment you can ignore this message
[22Apr2024 04:00:33.043] [main/WARN] [mixin/]: Reference map ‘octolib.refmap.json’ for octolib.mixins.json could not be read. If this is a development environment you can ignore this message
[22Apr2024 04:00:33.069] [main/WARN] [mixin/]: Reference map ‘EpheroLib-refmap.json’ for epherolib.mixins.json could not be read. If this is a development environment you can ignore this message
[22Apr2024 04:00:33.173] [main/WARN] [mixin/]: Reference map ‘simplyswords-forge-refmap.json’ for simplyswords.mixins.json could not be read. If this is a development environment you can ignore this message
[22Apr2024 04:00:33.255] [main/WARN] [mixin/]: Reference map ‘coroutil.refmap.json’ for coroutil.mixins.json could not be read. If this is a development environment you can ignore this message
[22Apr2024 04:00:33.263] [main/WARN] [mixin/]: Reference map ‘apexcore.refmap.json’ for apexcore.mixins.json could not be read. If this is a development environment you can ignore this message
[22Apr2024 04:00:33.273] [main/WARN] [mixin/]: Reference map ‘knavesneeds-forge-forge-refmap.json’ for knavesneeds.mixins.json could not be read. If this is a development environment you can ignore this message
[22Apr2024 04:00:33.280] [main/WARN] [mixin/]: Reference map ‘Aquamirae.refmap.json’ for aquamirae.mixins.json could not be read. If this is a development environment you can ignore this message
[22Apr2024 04:00:33.703] [main/ERROR] [net.minecraftforge.fml.loading.RuntimeDistCleaner/DISTXFORM]: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER
[22Apr2024 04:00:33.704] [main/WARN] [mixin/]: Error loading class: net/minecraft/client/gui/screens/Screen (java.lang.RuntimeException: Attempted to load class net/minecraft/client/gui/screens/Screen for invalid dist DEDICATED_SERVER)
[22Apr2024 04:00:33.704] [main/WARN] [mixin/]: @Mixin target net.minecraft.client.gui.screens.Screen was not found relics.mixins.json:ScreenMixin
[22Apr2024 04:00:33.807] [main/INFO] [Railways/MixinPlugin/]: com.railwayteam.railways.mixin.compat.voicechat.EntityAudioChannelImplMixin is not being applied because the mod(s) [VOICECHAT] are not loaded
[22Apr2024 04:00:33.808] [main/INFO] [Railways/MixinPlugin/]: com.railwayteam.railways.mixin.compat.voicechat.ServerMixin is not being applied because the mod(s) [VOICECHAT] are not loaded
[22Apr2024 04:00:33.809] [main/INFO] [Railways/MixinPlugin/]: com.railwayteam.railways.mixin.compat.voicechat.ServerWorldUtilsMixin is not being applied because the mod(s) [VOICECHAT] are not loaded
[22Apr2024 04:00:35.344] [main/WARN] [mixin/]: Error loading class: tfar/davespotioneering/blockentity/AdvancedBrewingStandBlockEntity (java.lang.ClassNotFoundException: tfar.davespotioneering.blockentity.AdvancedBrewingStandBlockEntity)
[22Apr2024 04:00:35.346] [main/WARN] [mixin/]: @Mixin target tfar.davespotioneering.blockentity.AdvancedBrewingStandBlockEntity was not found itemproductionlib.mixins.json:davespotioneering/AdvancedBrewingStandBlockEntityMixin
[22Apr2024 04:00:35.354] [main/WARN] [mixin/]: Error loading class: fuzs/visualworkbench/world/inventory/ModCraftingMenu (java.lang.ClassNotFoundException: fuzs.visualworkbench.world.inventory.ModCraftingMenu)
[22Apr2024 04:00:35.356] [main/WARN] [mixin/]: @Mixin target fuzs.visualworkbench.world.inventory.ModCraftingMenu was not found itemproductionlib.mixins.json:visualworkbench/ModCraftingMenuMixin
[22Apr2024 04:00:35.382] [main/WARN] [mixin/]: Error loading class: fuzs/easymagic/world/inventory/ModEnchantmentMenu (java.lang.ClassNotFoundException: fuzs.easymagic.world.inventory.ModEnchantmentMenu)
[22Apr2024 04:00:35.384] [main/WARN] [mixin/]: @Mixin target fuzs.easymagic.world.inventory.ModEnchantmentMenu was not found skilltree.mixins.json:easymagic/ModEnchantmentMenuMixin
[22Apr2024 04:00:35.388] [main/WARN] [mixin/]: Error loading class: dev/shadowsoffire/apotheosis/ench/table/ApothEnchantmentMenu (java.lang.ClassNotFoundException: dev.shadowsoffire.apotheosis.ench.table.ApothEnchantmentMenu)
[22Apr2024 04:00:35.389] [main/WARN] [mixin/]: @Mixin target dev.shadowsoffire.apotheosis.ench.table.ApothEnchantmentMenu was not found skilltree.mixins.json:apotheosis/ApothEnchantContainerMixin
[22Apr2024 04:00:35.393] [main/WARN] [mixin/]: Error loading class: dev/shadowsoffire/apotheosis/adventure/affix/socket/SocketingRecipe (java.lang.ClassNotFoundException: dev.shadowsoffire.apotheosis.adventure.affix.socket.SocketingRecipe)
[22Apr2024 04:00:35.394] [main/WARN] [mixin/]: @Mixin target dev.shadowsoffire.apotheosis.adventure.affix.socket.SocketingRecipe was not found skilltree.mixins.json:apotheosis/SocketingRecipeMixin
[22Apr2024 04:00:35.398] [main/WARN] [mixin/]: Error loading class: dev/shadowsoffire/apotheosis/adventure/affix/socket/gem/bonus/AttributeBonus (java.lang.ClassNotFoundException: dev.shadowsoffire.apotheosis.adventure.affix.socket.gem.bonus.AttributeBonus)
[22Apr2024 04:00:35.399] [main/WARN] [mixin/]: @Mixin target dev.shadowsoffire.apotheosis.adventure.affix.socket.gem.bonus.AttributeBonus was not found skilltree.mixins.json:apotheosis/AttributeBonusMixin
[22Apr2024 04:00:35.403] [main/WARN] [mixin/]: Error loading class: dev/shadowsoffire/apotheosis/adventure/affix/socket/gem/bonus/EnchantmentBonus (java.lang.ClassNotFoundException: dev.shadowsoffire.apotheosis.adventure.affix.socket.gem.bonus.EnchantmentBonus)
[22Apr2024 04:00:35.404] [main/WARN] [mixin/]: @Mixin target dev.shadowsoffire.apotheosis.adventure.affix.socket.gem.bonus.EnchantmentBonus was not found skilltree.mixins.json:apotheosis/EnchantmentBonusMixin
[22Apr2024 04:00:35.632] [main/WARN] [mixin/]: Error loading class: net/darkhax/darkutils/features/charms/CharmEffects (java.lang.ClassNotFoundException: net.darkhax.darkutils.features.charms.CharmEffects)
[22Apr2024 04:00:35.637] [main/WARN] [mixin/]: Error loading class: com/brandon3055/csg/ModEventHandler (java.lang.ClassNotFoundException: com.brandon3055.csg.ModEventHandler)
[22Apr2024 04:00:35.646] [main/WARN] [mixin/]: Error loading class: vazkii/quark/content/tweaks/module/AutomaticRecipeUnlockModule (java.lang.ClassNotFoundException: vazkii.quark.content.tweaks.module.AutomaticRecipeUnlockModule)
[22Apr2024 04:00:35.990] [main/INFO] [MixinExtras|Service/]: Initializing MixinExtras via com.llamalad7.mixinextras.service.MixinExtrasServiceImpl(version=0.3.5).
[22Apr2024 04:00:37.345] [main/INFO] [mixin/]: Mixing MixinLivingEntity from enigmaticlegacy.mixins.json into net.minecraft.world.entity.LivingEntity
[22Apr2024 04:00:37.795] [main/INFO] [mixin/]: Mixing MixinPlayer from enigmaticlegacy.mixins.json into net.minecraft.world.entity.player.Player
[22Apr2024 04:00:38.004] [main/INFO] [mixin/]: Mixing MixinMobEffect from enigmaticlegacy.mixins.json into net.minecraft.world.effect.MobEffect
[22Apr2024 04:00:39.463] [main/INFO] [mixin/]: Mixing MixinItemStack from enigmaticlegacy.mixins.json into net.minecraft.world.item.ItemStack
[22Apr2024 04:00:39.527] [main/INFO] [mixin/]: Mixing AccessorAbstractArrowEntity from enigmaticlegacy.mixins.json into net.minecraft.world.entity.projectile.AbstractArrow
[22Apr2024 04:00:39.790] [main/INFO] [mixin/]: Mixing MixinEnchantmentContainer from enigmaticlegacy.mixins.json into net.minecraft.world.inventory.EnchantmentMenu
[22Apr2024 04:00:39.790] [main/INFO] [mixin/]: Renaming synthetic method lambda$onEnchantedItem$0(Lnet/minecraft/world/item/ItemStack;Lnet/minecraft/world/inventory/EnchantmentMenu;ILnet/minecraft/world/entity/player/Player;ILnet/minecraft/world/level/Level;Lnet/minecraft/core/BlockPos;)V to md8fbf55$lambda$onEnchantedItem$0$0 in enigmaticlegacy.mixins.json:MixinEnchantmentContainer
[22Apr2024 04:00:40.578] [main/INFO] [mixin/]: Mixing MixinEnderEyeItem from enigmaticlegacy.mixins.json into net.minecraft.world.item.EnderEyeItem
[22Apr2024 04:00:40.623] [main/INFO] [mixin/]: Mixing MixinCrossbowItem from enigmaticlegacy.mixins.json into net.minecraft.world.item.CrossbowItem
[22Apr2024 04:00:41.838] [main/INFO] [mixin/]: Mixing MixinEnderDragon from enigmaticlegacy.mixins.json into net.minecraft.world.entity.boss.enderdragon.EnderDragon
[22Apr2024 04:00:41.839] [main/INFO] [mixin/]: Renaming synthetic method lambda$onTickDeath$0(Lnet/minecraft/server/level/ServerPlayer;)V to md8fbf55$lambda$onTickDeath$0$1 in enigmaticlegacy.mixins.json:MixinEnderDragon
[22Apr2024 04:00:42.088] [main/INFO] [mixin/]: Mixing MixinShulker from enigmaticlegacy.mixins.json into net.minecraft.world.entity.monster.Shulker
[22Apr2024 04:00:42.220] [main/WARN] [mixin/]: @Redirect conflict. Skipping securitycraft.mixins.json:camera.ServerPlayerMixin->@Redirect::securitycraft$tick(Lnet/minecraft/server/level/ServerPlayer;DDDFF)V with priority 1100, already redirected by railways-common.mixins.json:conductor_possession.ServerPlayerMixin->@Redirect::railways$securitycraft$tick(Lnet/minecraft/server/level/ServerPlayer;DDDFF)V with priority 1200
[22Apr2024 04:00:42.349] [main/INFO] [mixin/]: Mixing MixinVillagerEntity from enigmaticlegacy.mixins.json into net.minecraft.world.entity.npc.Villager
[22Apr2024 04:00:42.349] [main/INFO] [mixin/]: Mixing MixinVillager from enigmaticlegacy.mixins.json into net.minecraft.world.entity.npc.Villager
[22Apr2024 04:00:42.566] [main/INFO] [mixin/]: Mixing MixinBindingCurseEnchantment from enigmaticlegacy.mixins.json into net.minecraft.world.item.enchantment.BindingCurseEnchantment
  • start server
  • wait 20 seconds
  • crash for no reason
I’d suggest that you compare the latest.log against any crash logs you may have and see if there’s any correlation between the two that might point you in the right direction.
Or if you have a recent backup you could restore that instead.
