| Product | AMP ‘Phobos’ v2.6.0.12 (Mainline) |
| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Ready |
connexion lost every 10minutes i see that in the consoles
main/WARN
01:13:08
Reference map ‘muffins_picnic-fabric-refmap.json’ for muffins_picnic.mixins.json could not be read. If this is a development environment you can ignore this message
Reference map ‘starterkit_fabric.refmap.json’ for starterkit_fabric.mixins.json could not be read. If this is a development environment you can ignore this message
Error loading class: net/minecraft/class_906 (java.lang.ClassNotFoundException: net/minecraft/class_906)
@Mixin target net.minecraft.class_906 was not found porting_lib_tool_actions.mixins.json:FishingHookRendererMixin from mod porting_lib_tool_actions
Error loading class: pm/c7/scout/item/BaseBagItem (java.lang.ClassNotFoundException: pm/c7/scout/item/BaseBagItem)
@Mixin target pm.c7.scout.item.BaseBagItem was not found academy-common.mixins.json:scout.MixinBaseBagItem from mod academy
Error loading class: net/minecraft/class_310 (java.lang.ClassNotFoundException: net/minecraft/class_310)
@Mixin target net.minecraft.class_310 was not found academy-fabric.mixins.json:MixinMinecraftClient from mod academy
01:13:09
Error loading class: net/minecraft/class_329 (java.lang.ClassNotFoundException: net/minecraft/class_329)
@Mixin target net.minecraft.class_329 was not found cobblefoods.mixins.json:CustomHeartsMixin from mod cobblefoods
Error loading class: juuxel/adorn/block/variant/BlockVariantSets (java.lang.ClassNotFoundException: juuxel/adorn/block/variant/BlockVariantSets)
@Mixin target juuxel.adorn.block.variant.BlockVariantSets was not found mixins.cobblemon-common.json:invoker.AdornRegisterInvoker from mod cobblemon
Error loading class: io/github/apace100/apoli/power/factory/condition/ConditionFactory (java.lang.ClassNotFoundException: io/github/apace100/apoli/power/factory/condition/ConditionFactory)
Error loading class: net/minecraft/class_465 (java.lang.ClassNotFoundException: net/minecraft/class_465)
@Mixin target net.minecraft.class_465 was not found findme-common.mixins.json:MixinSlotRenderer from mod findme
Error loading class: net/minecraft/class_702 (java.lang.ClassNotFoundException: net/minecraft/class_702)
@Mixin target net.minecraft.class_702 was not found findme-common.mixins.json:ParticleEngineAccessor from mod findme
Error loading class: net/minecraft/class_988 (java.lang.ClassNotFoundException: net/minecraft/class_988)
@Mixin target net.minecraft.class_988 was not found mint.mixins.json:LlamaDecorFeatureRendererMixin from mod mint
Error loading class: org/betterx/betterend/complexmaterials/ColoredMaterial (java.lang.ClassNotFoundException: org/betterx/betterend/complexmaterials/ColoredMaterial)
Error loading class: vazkii/botania/common/block/block_entity/BotaniaBlockEntities (java.lang.ClassNotFoundException: vazkii/botania/common/block/block_entity/BotaniaBlockEntities)
Error loading class: vazkii/botania/common/block/BotaniaBlocks (java.lang.ClassNotFoundException: vazkii/botania/common/block/BotaniaBlocks)
Error loading class: vazkii/botania/common/handler/CompostingData (java.lang.ClassNotFoundException: vazkii/botania/common/handler/CompostingData)
Error loading class: vazkii/botania/fabric/FabricCommonInitializer (java.lang.ClassNotFoundException: vazkii/botania/fabric/FabricCommonInitializer)
Error loading class: vazkii/botania/common/item/FlowerPouchItem (java.lang.ClassNotFoundException: vazkii/botania/common/item/FlowerPouchItem)
Error loading class: vazkii/botania/data/recipes/ManaInfusionProvider (java.lang.ClassNotFoundException: vazkii/botania/data/recipes/ManaInfusionProvider)
Error loading class: vazkii/botania/common/entity/ManaSparkEntity (java.lang.ClassNotFoundException: vazkii/botania/common/entity/ManaSparkEntity)
Error loading class: vazkii/botania/client/core/handler/MiscellaneousModels (java.lang.ClassNotFoundException: vazkii/botania/client/core/handler/MiscellaneousModels)
Error loading class: vazkii/botania/common/handler/PaintableData (java.lang.ClassNotFoundException: vazkii/botania/common/handler/PaintableData)
Error loading class: vazkii/botania/common/block/flower/generating/SpectrolusBlockEntity (java.lang.ClassNotFoundException: vazkii/botania/common/block/flower/generating/SpectrolusBlockEntity)
Error loading class: com/simibubi/create/foundation/utility/DyeHelper (java.lang.ClassNotFoundException: com/simibubi/create/foundation/utility/DyeHelper)
Error loading class: mezz/jei/library/plugins/vanilla/crafting/replacers/ShulkerBoxColoringRecipeMaker (java.lang.ClassNotFoundException: mezz/jei/library/plugins/vanilla/crafting/replacers/ShulkerBoxColoringRecipeMaker)
Error loading class: fr/catcore/server/translations/api/resource/language/SystemDelegatedLanguage (java.lang.ClassNotFoundException: fr/catcore/server/translations/api/resource/language/SystemDelegatedLanguage)
we’r disconnected from the server with this message “disconnected time ou” without problem with the internet
- start and stop the server
- search the source of the problem
- try with a different settings on the server
