Startup Issue with Minecraft - Correct forge version not available?
Operating System Microsoft Windows 11 Home
The highest forge version I could do was 47.4.5, but my mods all require at least 47.4.10 and above. How do I fix this?? Or is there a way to make it available??
  • I’ve tried changing the java versions
  • I have tried manually replacing the java script in my files
It’s hard to find the correct version, the latter versions are mixed, keep looking and you’ll find. I had the same problem. I think the forge 47.4.10 is mixed up with the 1.21.x versions or something.
