Startup Issue with Minecraft - constant server downtime
Product AMP ‘Phobos’ v2.6.0.0 (Mainline)
Current State Starting
When you start the server after 2 min almost 3, the server restarts and starts the same action again and again
  • update mods and correctly understand the server
  • modification of the maximum and minimum ram
  • start playing and the errors started
To note, this is not Hostinger support.
Your best bet is to read the logs to see what mods are causing the issue.
