Startup Issue with Minecraft - Connection problems with the server
Product AMP ‘Callisto’ v2.5.1.6 (Mainline)
When some one tries to log in in to the server it comes to an error and you cant come in. Can’t keep up! Is the server overloaded? Running 3353ms or 67 ticks behind that is the error code which i get in the console.
  • Restart server
  • delet plugins
  • shut it down for a longer time
This error only means that your minecraft server is overloaded. This occours frequently right after startup, especially if your server is modded.
This does not mean that you cannot connect though.
You would need to get a bit more specific.
