Startup Issue with Minecraft - chunks don't load and an error message appears
Current State Sleeping
We’re using multiple Cobblemon mods. This error didn’t occur before, but it started happening at 9:17 UTC+9. A quick fix would be greatly appreciated.
  • Enter the server
  • Sometimes chunks don’t load, and even when the chunk I’m in loads, it returns to its original position every 2 seconds and then crashes.
  • Minecraft sends error code: “Internal Exception: java.net.SocketException: Connection reset”
  • The same thing happened even after restarting the server.
Please understand that this is the forum for AMP, and not Hostinger support, but we’ll try and get you pointed in the right direction.
You’ll want to read the server’s logs and any crash-logs to see if they have any information as to what caused the crash.
