Field | Value |
Operating System | Windows - Windows Server 2022 on x86_64 |
Product | AMP ‘Callisto’ v2.5.1.8 (Mainline) |
Virtualization | None |
Application | Minecraft |
Module | MinecraftModule |
Running in Container | No |
Current State | Failed |
we noticed permission problems and have deleted the files in config folder to have server recreate them (seems to have helped).
also ran the fix permission command for amp
This is a fresh Windows 2022 data server install. made amp username with admin perms.
we can get this running under mcserversoft but not under amp. these are the last few lines of our log.
[23:34:13] [main/INFO]: Hello Fabric world!
[23:34:13] [main/INFO]: File exists, reading config for elocindev.item_obliterator.fabric_quilt.config.ConfigEntries.
[23:34:13] [main/INFO]: Config for elocindev.item_obliterator.fabric_quilt.config.ConfigEntries read successfully.
[23:34:13] [main/INFO]: Item Obliterator Config Loaded
[23:34:13] [main/INFO]: Registering C2S receiver with id itemfilters:main/14e7fa1454283aec8ae811ef844ada28
[23:34:13] [main/INFO]: Registering C2S receiver with id itemfilters:main/8f6a899247753217b9d86ab427a2b279
[23:34:13] [main/INFO]: [jamlib] Mod initialized!
[23:34:13] [main/INFO]: [KONKRETE] Successfully initialized!
[23:34:13] [main/INFO]: [KONKRETE] Server-side libs ready to use!
[23:34:13] [main/INFO]: Compression will use Java, encryption will use Java
[23:34:13] [main/INFO]: Constructing common components for leavesbegone:main
- setup mc instance
- setup and run fabric to get files and folders in place
- copied PRominence 2 mods files over to server folder.
