Startup Issue with Minecraft bungee cord - Port is on red
Product AMP ‘Callisto’ v2.5.0.6 (Mainline)
No matter what I do the port keeps on red. I am trying to start a bungee cord server. I have managed to create a Minecraft server without problems. But I can make the port of the Bungeecord to turn green. The server says it is running. I just cannot access it
  • Check all settings and duplicated the settings of the Minecraft server (which is actually working)
  • Tested different ports
  • Changed the setting of the IP address inside of AMP
Double check that the port in the config.yml matches the instance’s game port
Thank you, This worked :slight_smile: :smiley:
