| Field |
Value |
| Operating System |
| Product |
AMP ‘Callisto’ v2.5.1.8 (Mainline) |
| Virtualization |
Docker |
| Application |
Minecraft Bedrock |
| Module |
GenericModule |
| Running in Container |
Yes |
| Current State |
Failed |
Unable to complete task
This task could not be completed: Running Update Tasks - - State: 3.
/bin/bash failed with exit code 8
- Select Minecraft Bedrock and create
- Click on manager instance
- Error prompt Unable to complete task This task could not be completed: Running Update Tasks - - State: 3. /bin/bash failed with exit code 8
same here
| Field |
Value |
| Operating System |
| Product |
| Virtualization |
Docker |
| Application |
Minecraft Bedrock |
| Module |
GenericModule |
Yes |
| Current State |
Failed |
Any updates on how I can resolve this? I am running a trial with some users and looking to convert to enterprise license but it seems like there are quite a few broken games.
This is due to Microsoft being a PITA.
Update your instance from the main instances page in AMP and then try to update the server again
I just tried. It seems to be forever stuck in Update step 3/9 - Server Download.
[08:37:44] [Core Info/1] : Starting AMP version 2.5.1.8 (Callisto), built 17/09/2024 12:32
[08:37:44] [Core Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[08:37:44] [Core Info/1] : Running in a Docker environment.
[08:37:44] [Core Info/1] : OS: Linux / x86_64
[08:37:44] [Core Info/1] : CPU: Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz (16C/16T)
[08:37:44] [Core Info/1] : RAM: 48173MB
[08:37:44] [Core Info/1] : AMP Instance ID: 9462c3ab-e213-4bbc-bb62-7595b5a720ee
[08:37:46] [Loader Info/1] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[08:37:46] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[08:37:46] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[08:37:46] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[08:37:46] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[08:37:46] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[08:37:46] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[08:37:46] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[08:37:46] [Loader Info/1] : GenericModule requests dependency steamcmdplugin…
[08:37:46] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[08:37:46] [Loader Info/1] : GenericModule requests dependency RCONPlugin…
[08:37:46] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[08:37:46] [Core Info/1] : Licence Present: AMP Professional Edition - Lifetime Licence
[08:37:46] [FileManager Notice/1] : No SSH keypair available for embedded server, generating new keypair…
[08:37:47] [FileManager Notice/1] : Generated new keypair with fingerprint Z4ALRqN6/pSLI86ybZPWmBaIXf9hyWvENUlLa5GeANg=
[08:37:47] [FileManager Notice/1] : Using keypair with fingerprint Z4ALRqN6/pSLI86ybZPWmBaIXf9hyWvENUlLa5GeANg=
[08:37:47] [FileManager Info/1] : SFTP Server started on 0.0.0.0:2226
[08:37:47] [Webserver Info/1] : Websockets are enabled.
[08:37:47] [Webserver Info/1] : Webserver started on http://127.0.0.1:8083
[08:37:47] [Logger Info/14] : RouterTimer@10Hz with 2 jobs started
[08:37:47] [Core Info/7] : Startup mode is UpdateAndStart.
[08:37:47] [Core Info/4] : Checking for AMP updates…
[08:37:48] [Core Info/5] : AMP is up to date.
[08:38:22] [Core Activity/18] : Authentication attempt for user admin from 127.0.0.1
[08:38:23] [Core Activity/5] : Authentication success
That’s all there is inside my logs.
