Startup Issue with Minecraft - application state: unable to run
I am trying to run a modified gregtech new horizons server and it will not start – I am unsure what I have done wrong.
Set the server jar to “autodetect” and then pick the Forge version in AMP that matches your server.
In the server settings, I set it to autodetect and then selected “forge-1.7.10-10.13.4.1614-1.7.10-universal.jar” as the server jar. Where can I go to pick the forge version in AMP?
Also, if it is of any use, when I try to run the server, this is the error I get –
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at cpw.mods.fml.relauncher.ServerLaunchWrapper.run(ServerLaunchWrapper.java:43)
at cpw.mods.fml.relauncher.ServerLaunchWrapper.main(ServerLaunchWrapper.java:12)
Caused by: java.lang.ClassCastException: class jdk.internal.loader.ClassLoaders$AppClassLoader cannot be cast to class java.net.URLClassLoader (jdk.internal.loader.ClassLoaders$AppClassLoader and java.net.URLClassLoader are in module java.base of loader 'bootstrap')
at net.minecraft.launchwrapper.Launch.<init>(Launch.java:34)
at net.minecraft.launchwrapper.Launch.main(Launch.java:28)
... 6 more
Thank you for the help with this, I really appreciate it.
