Field | Value |
Operating System | Linux - Ubuntu 24.04.2 on x86_64 |
Product | AMP ‘Phobos’ v2.6.2.2 (Mainline) |
Virtualization | None |
Application | Left 4 Dead 2 |
Module | GenericModule |
Running in Container | No |
Current State | Failed |
This is what I get when I try to start the server:
You must select a specific IP address for this server to function correctly in AMP. Selected: 0.0.0.0. Loopback (127.0.0.1) and Any IP addresses (0.0.0.0) are not supported. You must edit the ‘Application IP Binding’ setting network settings from ADS using the pencil icon and select the ‘Network and Ports’ tab.
- made server
- installed l4d2
- cant start server
