| Product | AMP ‘Decadeus’ v2.4.6.0 (Mainline) |
| Virtualization | Docker |
| Application | GatekeeperV2 Bot |
| Module | GenericModule |
| Current State | Failed |
User
File “/AMP/gatekeeperv2/GatekeeperV2-main/start.py”, line 105, in
Start = Setup()
File “/AMP/gatekeeperv2/GatekeeperV2-main/start.py”, line 46, in init
self.pip_install()
File “/AMP/gatekeeperv2/GatekeeperV2-main/start.py”, line 100, in pip_install
subprocess.check_call([sys.executable, ‘-m’, ‘pip’, ‘install’, ‘-r’, ‘requirements.txt’])
File “/usr/lib/python3.11/subprocess.py”, line 413, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command ‘[’/usr/bin/python3’, ‘-m’, ‘pip’, ‘install’, ‘-r’, ‘requirements.txt’]’ returned non-zero exit status 1.
- install all packages via terminal root
- updated phtyon
- verify all packages are install
