Startup Issue with Garry's Mod - Update to 2.6.2.4 Error starting IP address
Product AMP ‘Phobos’ v2.6.2.4 (Mainline)
Application Garry’s Mod
After updating ADS and all instances, I no longer have the ability to update the IP address bindings, as neither instance is ‘Multi-IP compatible’.
Please note that both servers where functioning prior to the updates, running on the same public IP on different port numbers.
Update: Restarting the instance a couple of times has now given me the option to change the IP address bindings
  • Start Instance
  • Manage instance to see startup error
  • Mentions I need to bind to an IP
  • Unable to change the IP bind from 0.0.0.0
