Startup Issue with Garry's Mod - Garrys Mod
Application Garry’s Mod
No Matter what i do i keep gettin Error Exit Code 139. ive tied spending hours with AI to helpo me but my Garrys Mod server wont start, TeamSpeak Will Start, Rust will Start. i dont know anymore
  • buy lisence
  • install AMP docker on unraid
  • do extra steps for MAC address parameter
  • enter lisence key
  • create username and passwort
  • start docker
  • create instance
  • Garrys Mod
  • Downloading Server Files
  • server doenst start, ip pinning
  • Change ip so docker’s ip (only available beside 0.0.0.0 and loopback)
  • Error Exit Code 139
This is not a supported setup. You will need to reach out to the docker image maintainer for help
